(2013-02-18, 12:33)stepir Wrote: [ -> ]not sure why but this build won't let me edit anything. When I click on a movie I can only start it.
Running from on MAC. Tried both from Safari/Chrome/Firefox
Are you sure you enabled XWMM as the web interface within the settings on XBMC? It sounds like some other interface is set as the default since XWMM doesn't play movies (if that's what you meant by "start it".)
+1 Zernable Thanks
Hey keibertz. Thanks. Your German "How To" translated easy and I am now up and running. Another happy customer.
Hi got this up and runining last night cheers, but never used it before and was just wondering how you add and remove movies to sets? cheers
If you're using Zernable's update, then Movie Sets aren't supported yet. (Hopefully soon!!)
(2013-02-17, 05:12)Zernable Wrote: [ -> ]Features not yet working- Changing artwork
- Managing movie sets, genres and actors (although these can be changed on a per movie/TV/music basis)
- The "Files" tab
My bad sorry i missed that, cheers
Hey wints,
I was just thinking ... maybe I'm mistaken as to what you are asking...
If you're trying to manage movie sets from the tools section (eg. remove set named "American Pie Collection" - that doesn't work.
However if you are just trying to remove "American Reunion" from the collection - you can do that by clicking the movie, clicking Other Details, deleting whatever is in the "Sets" section, and finally clicking Save at the bottom.
Cheers for the headsup LakersFan, can you add movies to sets in the same way or is it just remove that is working for now? cheers again
You can add and remove movies from existing sets (and genres). What is currently not functional is adding brand new sets (and genres) or removing unused ones.
i like the funktion to sort by genre. Hope this one will work soon.
(2013-02-17, 05:12)Zernable Wrote: [ -> ]I have created an "unofficial" version of XWMM for Frodo. Most of the functionality of the Eden version is working including editing of movie, TV and music metadata.
- The "Files" tab
Thanks a million for this! Can't wait for the full version!
Unofficial frodo version works good but its a bummer I cant change the poster or fanart.
What available solutions are there to manually edit the library (on frodo)?? All I want to do is be able to manually add covers to things the scrapper cant find.
u can change the cover manually directly in XBMC in the movieinfo screen (Button i)
thanks, forgot that was possible.
Superb, I will try immediately!
