Full Version: Backgrounds on AppleTV with Rapier?
Hey! I've just started using XBMC with the AppleTV again (r24183). I've been using XBMC with Xbox for years. I like the look of the Rapier 2.0 skin! Maybe someone here could help me with a user problem. Where do I put my background pic folders so that they'll show up on the Home screen? Right now, when I go to Skin Settings --> Backgrounds, I select Use Multi Image for Background and then select Multi Image Path, I get an empty browse window. Even if I try to create a New Folder, it doesn't show up.
I'm sure I'm missing something obvious...
This appears to be a problem with the latest SVN builds. I've reverted to the stable 9.0.4.1 build and browsing works properly.
