2009-11-05, 00:59
2009-11-05, 00:59
2009-11-05, 01:11
you can hit 'i' on keyboard / 'info' on remote to toggle the info between permanently visible or hide after a number of seconds.
you can also specify a custom time in advancedsettings.xml.
see: http://wiki.xbmc.org/?title=Visualizations
2009-11-05, 03:41
ronie Wrote:you can hit 'i' on keyboard / 'info' on remote to toggle the info between permanently visible or hide after a number of seconds.
thank , analyzing ... I'm having a little trouble!
I copied the code and saved in notpad "advancedsettings.xml"
what code should I change and where should I put "advancedsettings.xml"
2009-11-05, 09:26
let's say you want the info to stay on screen for two minutes:
save the file to your userdata folder.
the location of the userdata folder depends on the platform you're using.
<advancedsettings>
<songinfoduration>120</songinfoduration>
</advancedsettings>
2009-11-17, 14:38
ronie Wrote:let's say you want the info to stay on screen for two minutes:
Code:<advancedsettings>
</advancedsettings>
Friend, thank you. following their tips could do what he intended
HEALTH AND PEACE
THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU,
