Full Version: THE 1.1 Skin Compability List!
Pages: 1 2 3
xbmc 1.1.0 is now officially released. this topic will now be pinned so you can easily find compatible skins for this version
Quote:
skin name :: location :: compressed :: support modes
• project mayhem :: cvs :: yes :: 4:3, 16:9, hdtv
• blackblue classic :: xbox-skins :: yes :: 4:3, 16:9
• green fields :: xbox-skins :: yes :: 4:3, 16:9
• xbmc mce :: forumthread :: yes :: 4:3, basic 16:9
• blueswirl :: xbox-skins :: yes :: 4:3
• zippo :: xbox-skins :: no :: 4:3
• visor :: xbox-skins :: no :: 4:3
• spacestation alpha :: xbox-skins :: yes :: 4:3, 16:9, hdtv-1080i (skin not finished, beta??)
• symbol :: xbox-skins :: yes :: 4:3, 16:9
• project helix :: axb :: yes :: 4:3, 16:9
last updated: 2005-03-23
blackblue classic :: http://www.xbox-skins.net/index.p....id=1721 :: yes :: pal 4:3 :: pal 16:9
green fields:: http://www.xbox-skins.net/index.p....id=2022 :: yes :: pal 4:3 :: pal 16:9
added to list Smile
suggestion: "does it have support for hdtv 720p (etc)" would be nice, as the skins are not really useful for those that only use xbmc in hdtv modes unless they do. i'm not meaning to be nasty, i just think it should be required for a full release skin.
@ anomaly
hmm.. i highly doubt many skinners have hdtv equipment, or equipment to test that, how many skins used to be hdtv compliant?
even, how high % of our users have hdtv's? any idea?
the scope of this list should imho be to gather skins that function and doesnt cause problems in normal pal/ntsc usage for use with the upcoming 1.1 point release. note though that i'll take valid reasons you may have under careful consideration!
striker, xpr packed? Shocked
"mce" is compatible, but i would prefer if you link to the thread instead of directly to the file because i will probably update it at least once before 1.1.0 comes out.
http://www.xboxmediaplayer.de/cgi-bin....;t=6195
i will probably post it on xbox-skins and allxboxskins after 1.1.0 comes out.
the textures are packed, but a rar file of the actual images is included so people can modify it.
my other skin "blueswirl" has also been updated to support 1.1.0.
http://www.xbox-skins.net/index.php?download=1644
the textures in that skin are packed into an xpr file as well.
mce has basic 16x9 support, blueswirl is 4:3 only.
pike dont forget to mention bb and green fields support 16:9 Wink
i was waiting for you to inform me Smile added now...
zippo , uncompressed, http://www.xbox-skins.net, 4:3
visor, uncompressed, http://www.xbox-skins.net, 4:3
added!
i'll probably upload a new update tonight on xbox-skins.net of my skin "symbol"
http://www.xbox-skins.net/index.php?download=2075
but the 27/9 version is working ok with latest xbmc cvs too.
it's compressed and pal 4/3. (no ntsc support yet)
pike, i saw your message about the ram bugs on sf, i didn't check them very well for now but looks like the "item not found" bug is still there.
i'll post my testings on sf as soon as possible.
ciaoo.
i'll add the skin when you've tested it for both pal & ntsc ok?
ok but to make ntsc will take me some time.
Pages: 1 2 3
