Full Version: Minibox M200LCD?
I am looking at this case for my XBMC HTPC build.
http://www.mini-box.com/Mini-Box-M200-LCD
However, I have few questions:
1.) Spec says 2.5" HDD is supported, will a 3.5" fit in this case? 2.5" drives are hard to find, and expensive
2.) Is the LCD display really that useful in XBMC? What functionality can you get out of it? I remember the old SmartX LCDs for the Xbox, but never could justify buying one back then.
3.) Zotac Ion board I plan to buy (Atom 330) has an external PSU. How would this work with this case?
4.) I have read that the the Zotac boards won't fit this case with the CPU fan. Is passive cooling sufficient with the ION 330?
I plan to run XBMC on top of a minimal Ubuntu install, or just install XBMC Live to HDD.
I will be going with a Zotac Ion 330, 2 GB of RAM, 1 TB Seagate HDD. I am scrapping the optical drive since there is no opensource library for playing back blu-ray, so this case would work well.
I am looking for small form-factor case, close to set-top box size. If this case will not work, and recommended cases that meet these requirements? Thanks for any suggestions. This is going to be a fun build!
3.5" inch hdd won't fit.
I like this case.
http://www.thermaltake.com.au/Products/C...SD100.aspx
