Full Version: Huge Problem With the ALPHA VERSION
Hello!
when trying to connect to my PC via SMB i always got this message:
FUNCTION NOT IMPLEMENTED
can someone please help me
please help i really need SMB to work cause i got all my files on my pc
Try mounting the drive in linux via SMB and pointing XBMC to the local mountpoint. This has always worked better than the XBMC SMB implementation anyway.
Should really state which OS your running. Running Karmic? search the forums.
And bumping your thread before 24 hrs is frowned upon... Doing so in less than 1 hour is just ridiculous at best.
i am using the XBMC Live 9.11 Alpha1
i don´t know witch version it uses
i have done apt-get install smb
and the problem wasn´t solved
please some help
tslayer
sorry my intention was not to pump
As pointed out in your other thread, debug log needed.
