Full Version: XBMC Freezing on launch
Apple TV
Launcher 3.1
XBMC 9.11 Alpha1
Install method: Launcher
Whenever I launch XBMC the Apple Logo shows up and it sits there for a few seconds, then it flashes and part of the white menu bar shows up along the top. It freezes here and I have to reboot.
I mentioned that I'm using the latest Alpha, but this has been happening for a bit now with some of the latest SVNs. I can't recall when it first started though.
Before I installed the update (or any SVNs) I backed up the old XBMC and I could successfully launch XBMC. I was hoping the latest Alpha would clear things up, but alas it hasn't.
XBMC.log
http://pastebin.com/m38ddc73d
Crash log:
http://pastebin.com/m796aa264
What ATV version do you have?
What resolution are you running?
First thing I'd do is to move ~/Library/Application\ Support/XBMC out of the way and reinstall XBMC 9.10.alpha1 through Launcher. If it still doesn't work, please post xbmc.log again.
Thanks,
mdd
Apple TV 2.3.1 and 1080p
What you suggested worked.
Apple TV v2.4
Launcher 3.1
XBMC 9.11 Alpha1
1080p
Just wanted to report the exact same issue when installing Camelot on . If I re-install Babylon I'm back in business. I'll try the suggested fix
OK, Got round to trying this. Realised that I can't move the directory via Fugu (i'm guessing elevated permissions thing) and I don't know how to do it via a Terminal. Can anyone help me out with some Terminal Commands I can copy and paste please?
logan_x50 Wrote:OK, Got round to trying this. Realised that I can't move the directory via Fugu (i'm guessing elevated permissions thing) and I don't know how to do it via a Terminal. Can anyone help me out with some Terminal Commands I can copy and paste please?
mind posting console.log and xbmc.log?
To move a directory around use
mv $SOURCE $TARGET
To delete a directory and all of its content do
rm -r $PATH_TO_DIRECTORY
Keep in mind that spaces need to be escaped with "\", so to remove e.g. "~/Library/Application Support/XBMC" you'll need to do
rm -r ~/Library/Application\ Support/XBMC
Thank you MaestroDD
Hopefully, this is what you need...unless you need logs prior to putting Babylon back on my ATV?
http://pastebin.com/m37dc6327
http://pastebin.com/m205f5b59
Deleted the directory and now Camelot launches Smile
logan_x50 Wrote:[...]
yep, exactly. Thanks!
logan_x50 Wrote:Deleted the directory and now Camelot launches Smile
glad it's working...
