When I enabled SSH on ATV3.0 with the patch stick it created this dud "Software menu".
Is there a thread that describes how to get rid of it? I tried looking for a search forum facility but couldn't find it.
Regards,
Omar
omarmasri Wrote:Hi,
Regards,
Omar
You can ssh into the atv and remove it. So cd to
/System/Library/CoreServices/Finder.app/Contents/PlugIns
Issue ls to make sure it's there.
Then sudo rm -r softwaremenu.frappliance
pmcd
Stuck with this bit:-
ssh to your TV and install it to the plugins folder (/System/Library/CoreServices/Finder.app/Contents/Plugins/)
how?? thx
"Install" simply means copy or move here. ;-)
Use sudo mv [source] [destination] for this.
Hmm, thought I had posted already, but it seems to have disappeared
Anyway, I tried and successfully removed the menu as per instructions detailed above.
Subsequently I upgraded XBMC to RC1 and the menu appeared again.
This time I cannot find it in /System/Library/CoreServices/Finder.app/Contents/Plugins/ -
any ideas where it might be or what to do now to get rid of this menu item.
Thanks in advance
EDIT: Never mind.
This seems to have fixed itself. I turned my TV on this morning and noticed that the ATV
was in the Apple menus - not in XBMC where I left it.
I assume that is crashed or rebooted itself - all's well now.
