Full Version: USB devices are not mounted automatically
I'm having troubles with the automatic mounting of USB storage devices, XBMC just doesn't recognise them.
I installed XBMC 9.11 alpha 1 r24283 on Ubuntu Jaunty i686 (I mostly followed this guide even though I don't have an Acer Revo)
Here is a debug log where I started XBMC and then plugged in the external HD.
Here is another one where I first plugged in the HD and then started XBMC (don't know if it makes a difference)
dmesg output
hal-device output
Any help would be very appreciated.
Hi and welcome to the forums, there seems to be a regression regarding this. I have a fix and will commit it ASAP.
So it should be fixed in next release.
in the meantime you may add an advancedsettings.xml with the following and it should work.
<advancedsettings>
<handlemounting>true</handlemounting>
</advancedsettings>
P.S Thanx for a splendid bugreport!
cheers,
Tobias
Thanks for the advice, additionally I had to execute
sudo polkit-auth --user xbmc --grant org.freedesktop.hal.storage.mount-removable
