Do you have a file called tvshow.nfo in the tv show folders? In the log it frequently says
"Asked to lookup episode X online, but we have no episode guide. Check your tvshow.nfo and make sure the <episodeguide> tag is in place."
If you are using tvshow.nfo files make sure they are correct or remove them.
No, I have no nfo file in there.
All i have is:
Scrubs - s1e1 - episode name.avi
Mymovies.xml
\metadata folder
The above files are from MCE and media browser app.
I tried removing all those files and just leaving avi information but no luck.
dallasf Wrote:No, I have no nfo file in there.
All i have is:
Mymovies.xml
\metadata folder
did you ever notice xbmc already jumps off the table at your MOVIES?
also, it should read Scrubs -
s01e01 - blah.avi
Movies are cool, no issue.
Had tv shows like that s01e01 and changed it to s1e1 to see if it made a difference. There was no difference.
Getting way to bizarre and way to hard really!
try removing that Mymovies.xml and rescan
camelot a1 had a bug that made it always grab mymovies.xml. this is fixed in a2.
Sweet ill give it a go and let you know.
No luck with A2, now there is code appearing in the TV Shows and Arressted Development is not even recongised as a show.
0 episodes on all TV shows. Same log as before with errors.
I even changed scraper providers and no luck.
