Full Version: TV Fan art and images
i have a windows xp pro running 9.11 alpha and it wont download the images for the tv shows, i have the scraper set to the default and i cant figure out why it wont download images and the movies will. its problem has carried over from the previous version i was running.
i was wondering if any one had any ideas
not without a log. see my signature.
probably because your tv shows dont follow the folder/file name format that they should be in for xbmc to find the show.
it works perfectly on my ubuntu machine and its using the same directory as the windows machine
still no log...
here is a chunk of the log file, its long, i can post the whole thing if you want
19:25:02 T:1700 M:598474752 ERROR: Texture manager unable to load file: special://skin/images/studios/.png
19:25:02 T:1700 M:598552576 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\Penguins of madagascar, the\
19:25:02 T:1700 M:598474752 WARNING: DIRECTORY::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 12
19:25:02 T:340 M:598458368 ERROR: InputStream: Error opening, k:\tv\Penguins of madagascar, the\The.Penguins.Of.Madagascar.S01E01.Launchtime.REPACK.DSR.XviD-ETACH.avi
19:25:02 T:340 M:598458368 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\Penguins of madagascar, the\
19:25:02 T:340 M:591532032 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
19:25:03 T:340 M:595668992 ERROR: InputStream: Error opening, k:\tv\Penguins of madagascar, the\The.Penguins.Of.Madagascar.S01E03.Haunted.Habitat.DSR.XviD-ETACH.avi
19:25:03 T:340 M:595668992 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\Penguins of madagascar, the\
19:25:03 T:340 M:591888384 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
19:25:03 T:1700 M:595054592 ERROR: PICTURE: Error loading image special://skin/images/studios/.png
19:25:03 T:1700 M:595054592 ERROR: Texture manager unable to load file: special://skin/images/studios/.png
XBMC not downloading new images? READ THIS
i was able to replace 15 occurrences, hopefully this will fix it i will let every one know about the outcome.
