Hi i´m not a unix guru and use my mac on icons.
My XBMC had run on 2.4 an the automatic update have delete all my aTV System. Now it is 3.01 no XBMC my Patchstick will dont work.
Back to 2.3 isntall XBMC wil download but the launcher dont want download or when it download than had a erron in script 126.
Back to the roots No XBMC
Update on 3.01 No XBMC.
What can i do now.
My TV is now updated on 3.0.1 no patched.
I dont know which Patchstick i must take.
I dont know what i must do with Laucher-3.2 beta.
I dont know how i put the XBMC on my aTV.
I dont know how i can connet my Mac Mini with the aTV for transver and recover.
Thanks for help and begin to the roots.
Michael
michael m. Wrote:Hi i´m not a unix guru and use my mac on icons.
What can i do now.
Michael
covered already in at least two threads.
Where are the two threads?
Thanks Michael
Thank you,
it is very exactly. I have understand what i have done.
Now i have a new Problem.
On Apple TV Launcher/Downloads
In Launcher i want to install XBMC.
The next error MEssage is now:
No Downloads found!
URLs tried ("http://atv-xbmc-launcher.googlecode.com/svn/tags/ul-info/update_urls.plist")
I have connet with Cyberduck to Apple TV for copying the XBMC File in the App Folder of the AppleTV!
Where must be the App Files?
thanks
Michael
michael m. Wrote:Thank you,
No Downloads found!
thanks
Michael
you need to place XBMC.app in /Users/frontrow/Applications
then ssh to ATV and do:
sudo ln -s /Users/frontrow/Applications/XBMC.app /Applications/XBMC.app
after that you will be able to start XBMC from Launcher menu.
It would be better to try and download via Launcher, I am not sure why it failed for you. I can access the url without problem.
Same problem posted in a new treat.
