2009-11-12, 23:06
I would like to make some custom changes to my keymappings, specifically for the harmony remote. the problem is i only want to change 4-5 different keys the rest i want to be default. i was reading if i keep only the changes (properly formatted ofcourse) in user/application support/plex/keymaps rather than the system/application support/plex directory where the default files are found, it will check forthe changes at startup and that way if i upgrade xbmc my changes will remain intact. the problem is i have tried that but unless i make the changes to the original file and leave in its original location none of the changes gets implemented, so i would constatnly have to restore copy every time i upgrade xbmc, which can sometimes be eveyr couple of days. can someone suggest if this infact should work and im doing something wrong?
