Full Version: Microsoft Xbox Wireless Controller (xbox1 controller) no input in irw
Hi.
I'm having a problem with my xbox 1 controller (Microsoft Xbox Wireless Controller) and XBMC/Ubuntu.. This is not the dvd remote, this is a controller.
First of all, controller is tested in windows and works fine there.
Most of the buttons work in XBMC out of box as well. Exept D-Pad, back, start and volume on right analog stick is upside down.
Installed lirc, but i'm getting no output to irw, so it's hard for me to map the buttons.
Furthermore I have no idea on how to config lircd.conf with button names.
lirc starts and stops fine.
Here are some data :
From hardware.conf, bold lines edited :
Quote:# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="Logitech Xbox Wireless Controller"
REMOTE_MODULES=""
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF=""
REMOTE_LIRCD_ARGS=""
cat /proc/bus/input/devices show :
Quote:I: Bus=0003 Vendor=046d Product=ca84 Version=0103
N: Name="Logitech Xbox Cordless Controller"
P: Phys=usb-0000:00:04.0-6.1/input0
S: Sysfs=/devices/pci0000:00/0000:00:04.0/usb2/2-6/2-6.1/2-6.1:1.0/input/input5
U: Uniq=
H: Handlers=event5 js0
B: EV=b
B: KEY=683f0000 400000 0 0 0 0 0 0 0 0
B: ABS=3003f
When I start lirc it show :
Quote:xbmc@htpc:~$ sudo /etc/init.d/lirc restart
* Stopping remote control daemon(s): LIRC [ OK ]
* Loading LIRC modules [ OK ]
* Starting remote control daemon(s) : LIRC [ OK ]
xbmc@htpc:~$
daemon log says :
Quote:Nov 13 22:15:40 htpc lircd-0.8.6[2382]: caught signal
Nov 13 22:15:40 htpc lircd-0.8.6[2446]: config file contains no valid remote control definition
Nov 13 22:15:40 htpc lircd-0.8.6[2447]: lircd(default) ready, using /var/run/lirc/lircd
Nov 13 22:16:04 htpc lircd-0.8.6[2447]: accepted new client on /var/run/lirc/lircd
Nov 13 22:16:04 htpc lircd-0.8.6[2447]: could not get file information for /dev/lirc
Nov 13 22:16:04 htpc lircd-0.8.6[2447]: default_init(): No such file or directory
Nov 13 22:16:04 htpc lircd-0.8.6[2447]: Failed to initialize hardware
Nov 13 22:16:09 htpc lircd-0.8.6[2447]: removed client
I have no idea anymore, been reading a ton of guides and gotten nowhere.. This should be possible right ?
Hope anyone can help me get any further with this one.
Thanks in advance.
.. sorry no comment.. thought i saw something .. guess not
got everything working with xboxdrv now, removed lirc alltoghether, since it's not needed for this controller to work.
just need to find out how to wrap xboxdrv around xbmc as a daemon, so it can autostart now Smile
EDIT :
Found the solution to autostarting xboxdrv with all parameters (without stalling the loading of xbmc) :
Quote:sudo nano /etc/init/tty2.conf
replace this line :
Quote:exec /sbin/getty -8 38400 tty2
with :
Quote:exec /home/xbmc/xboxdrv/xboxdrv –silent –dpad-as-button –deadzone 3000
Ta-daaa ! You can now use your old xbox1 controller.
Much thanks to this guide here : http://stolennotebook.com/anthony/2008/0...r-xboxdrv/
