I just upgraded my perfectly working 9.04 to 9.11A2. I tried A1 but it had alot of problems. After the upgrade to A2 I have not been able to update my video library.
After a couple of retrys, I deleted my video DB, then I set content - TV shows - automatically scan all
here is my debug log.
http://pastebin.com/m75f80f2d
The problem is new with this version of XBMC.
It looks like this is my problem. Could not connect..
13:30:25 T:59067248 M:1710997504 DEBUG: FillBuffer: Reconnect, (re)try 2
13:30:29 T:2911894384 M:1711005696 DEBUG: CDVDPlayerAudio:: Discontinuty - was:30755916.513347, should be:30744073.788576, error:-11842.724771
13:30:35 T:59067248 M:1711017984 DEBUG: FillBuffer: curl failed with code 28
13:30:35 T:59067248 M:1711017984 DEBUG: FillBuffer: Reconnect, (re)try 3
13:30:45 T:59067248 M:1711038464 DEBUG: FillBuffer: curl failed with code 28
13:30:45 T:59067248 M:1711038464 DEBUG: FillBuffer: Reconnect failed!
13:30:45 T:59067248 M:1711038464 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:30:45 T:59067248 M:1711038464 DEBUG: FileCurl::Close(0x9d485e0) http://www.thetvdb.com/api/GetSeries.php?seriesname=dora%20the%20explorer&language=
13:30:45 T:59067248 M:1711038464 DEBUG: No NFO file found. Using title search for 'smb://xbmc:xbmc@WRT160NL/public/Video/shows/Other/'
