Full Version: How to edit movie info
I want to edit movie info manually.
Where are the files stored where the info is? Cant find anywhere Nerd
There is no way to edit the database directy from within XBMC.
This plus the plethora of external meida managers might give you some hints.
http://www.xbmc.org/wiki/?title=Import_-_Export_Library
Yeah i didnt mean in XBMC, i mean theres probably some .xml files somewhere which i need to edit, but i cant find them. The import-export is too weird, i dont understand it at all. I imported the database to 1 file and tried to edit it, but it didnt contain the same info than what i see in XBMC. For example plots for movies were different in the XML and in XBMC Huh Plus when I exported it back, I lost some thumbnails and fanart I had manually put there earlier
what do you mean by "external media managers"?
Havent heard of them
look a little below the import export section and read about nfo file support.
There is a complete section here on the forum dedicated to these programs:
http://forum.xbmc.org/forumdisplay.php?fid=116
sho Wrote:There is a complete section here on the forum dedicated to these programs:
thanks for that!
I DL'd Media Companion. When I edit the info, it successfully saves the new info in the .nfo file. But when I update the library in XBMC, nothing changes there, I still see the old infoHuh
What am I doing wrong now?
tubbana Wrote:thanks for that!
i'm not sure if xbmc detects changes in .nfo files?
you can manually refresh the info for each individual movie, check if that works.
Thanks! Reloading individually works Smile
better than nothing Smile
edit: well fanart editing with media companion doesnt seem to work
Check out XBNE in the supplementary tools section - does a great job of editing nfos AND XBMC database directly Smile
