I have tried 2 builds of XBMC on an Xbox and get the same result. When I try to add a SMB path I get "invalid computer name"
I have tried adding IP address instead of hostname, verified workgroup is correct, WINS is blank, no typos, share name is correct. I'm fluent with networking but new to XBMC.
XP SP3 system with known good network shares on it that other Windows systems can browse and mod files.
Everything I read online points to sources.xml file but this file is not present on my xbox under the userdata or any other directory. I thought of getting a sample sources.xml and placing it there but haven't yet.
T3CH XBMC 2009-06-01 9.04.1-FIXED-Babylon
What's your log say?
Have you set the network settings in XBMC configuration?
I keep getting errors trying to post the logs, saying there are images and BB code but I will try to get the log contents posted. Here is the first part:
13:46:41 M: 57274368 NOTICE: -----------------------------------------------------------------------
13:46:41 M: 57253888 NOTICE: Starting XBMC, Platform: Xbox. Built on Jun 1 2009 (SVN:20848, compiler 1310)
13:46:41 M: 57253888 NOTICE: special://xbmc/ is mapped to: Q:\
13:46:41 M: 57253888 NOTICE: special://masterprofile/ is mapped to: q:\UserData
13:46:41 M: 57253888 NOTICE: special://home/ is mapped to: Q:\
13:46:41 M: 57253888 NOTICE: special://temp/ is mapped to: Z:\
13:46:41 M: 57253888 NOTICE: The executable running is: E:\Apps\XBMC\default.xbe
13:46:41 M: 57253888 NOTICE: Log File is located: Q:\xbmc.log
13:46:41 M: 57253888 NOTICE: -----------------------------------------------------------------------
13:46:41 M: 57253888 NOTICE: Unmapped drive T
13:46:41 M: 57253888 NOTICE: Mapping drive T to Harddisk0\Partition1\Apps\XBMC\UserData
13:46:41 M: 57253888 NOTICE: Setup DirectX
13:46:41 M: 57229312 NOTICE: Mapping drive C to Harddisk0\Partition2
13:46:41 M: 57229312 NOTICE: Mapping drive E to Harddisk0\Partition1
13:46:41 M: 57229312 NOTICE: Unmapped drive D
13:46:41 M: 57229312 NOTICE: Mapping drive D to Cdrom0
13:46:41 M: 57229312 NOTICE: Mapping drive F to Harddisk0\Partition6
13:46:41 M: 57229312 NOTICE: Mapping drive X to Harddisk0\Partition3
13:46:41 M: 57229312 NOTICE: Mapping drive Y to Harddisk0\Partition4
13:46:41 M: 57229312 NOTICE: Unmapped drive Z
13:46:41 M: 57229312 NOTICE: Mapping drive Z to Harddisk0\Partition5
13:46:41 M: 57229312 NOTICE: load settings...
13:46:41 M: 57229312 NOTICE: Mapping drive P to Harddisk0\Partition1\Apps\XBMC\UserData
13:46:41 M: 57229312 NOTICE: special://profile/ is mapped to: q:\UserData
13:46:41 M: 57229312 NOTICE: loading special://masterprofile/guisettings.xml
13:46:41 M: 57073664 NOTICE: Getting hardware information now...
13:46:41 M: 57073664 NOTICE: Checking resolution 10
13:46:41 M: 57073664 NOTICE: Setting autoresolution mode 4
13:46:41 M: 57069568 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
13:46:41 M: 57069568 NOTICE: Default Video Player: mplayer
13:46:41 M: 57069568 NOTICE: Default Audio Player: paplayer
13:46:41 M: 57069568 NOTICE: Per AV pack settings are off
13:46:41 M: 57180160 NOTICE: q:\UserData\sources.xml
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button browser_home
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button browser_favorites
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button browser_refresh
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button browser_search
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button launch_app1_pc_icon
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button launch_media_select
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button play_pause
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button stop
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button volume_up
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button volume_mute
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button volume_down
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button next_track
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button prev_track
13:46:41 M: 50409472 ERROR: Keyboard Translator: Can't find button launch_mail
13:46:41 M: 50679808 NOTICE: Network: Using dashboard IP settings
13:46:42 M: 50352128 NOTICE: Checking the Date!
13:46:42 M: 50352128 NOTICE: start dvd mediatype detection
13:46:42 M: 50286592 NOTICE: initializing playlistplayer
13:46:42 M: 50286592 NOTICE: DONE initializing playlistplayer
13:46:42 M: 50278400 NOTICE: load default skin:[Project Mayhem III]
13:46:43 M: 46084096 NOTICE: initialize done
13:46:43 M: 46084096 NOTICE: Running the application...
13:46:44 M: 45420544 NOTICE: Webserver: Starting...
13:46:44 M: 45715456 NOTICE: Webserver: Started
13:46:44 M: 45711360 NOTICE: XBFileZilla: Starting...
13:46:44 M: 45645824 NOTICE: ES: Starting event server
13:46:44 M: 44584960 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:46:44 M: 44584960 NOTICE: UDP: Listening on port 9777
13:46:44 M: 39366656 NOTICE: XBFileZilla: Started
13:47:55 M: 44154880 WARNING: CUtil::GetMatchingSource... no matching source found for [Video plugins]
HERE IS THE SECOND PART.
I had to make this an image to post it. Sorry it's displaying a little small.
The issue is with the way you have configured your SMB shares within XBMC.
smb://
server%5cuser:password@Server/data/blah/blah
I am guessing that something has substituted the "SPACE" character with a %5c
Here are some examples:
smb://myfileserver/myshare
Currently your servers name is "server " ***NOTE THE SPACE CHARACTER, space is not an appropriate character within a computer name.
A hint for those of you who are new to sharing on XP.
After you think that you have configured your shares, you should attempt to connect to them from the same PC.
Open "My Computer"
in the Address Bar, type in "\\computername" without the quotes
To find your computername, right click on My Computer and click properties, it is listed in there under the computername section.
After putting \\computername in the addressbar, ALL of the shares should be listed.
If you are unable to see any shared folders listed, you have done your sharing WRONG.
So you now have found:
ComputerName
ShareName
with these details you can fix your smb:// path in the config file
if you have not made the shares anonomous or readable by "Everyone" you will need to also add a username and password to the smb:// setting.
If you need help creating the smb:// string, you will need to tell me:
computername
sharename
username
password
