2009-11-16, 21:35
some time when my xbmc starts up it gers this error: Windows no disk i dont have any cds in the drive and all the files are on a local drive.
LOG:
12:57:06 T:2400 M:621858816 NOTICE: -----------------------------------------------------------------------
12:57:06 T:2400 M:621821952 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Jun 2 2009 (SVN:20672, compiler 1500)
12:57:06 T:2400 M:621821952 NOTICE: AMD Athlon 64 Processor 3500+
12:57:06 T:2400 M:621821952 NOTICE: Desktop Resolution: 1024x768 32Bit at 60Hz
12:57:06 T:2400 M:621821952 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
12:57:06 T:2400 M:621821952 NOTICE: special://masterprofile/ is mapped to: C:\Program Files\XBMC\userdata
12:57:06 T:2400 M:621821952 NOTICE: special://home/ is mapped to: C:\Program Files\XBMC
12:57:06 T:2400 M:621821952 NOTICE: special://temp/ is mapped to: C:\Program Files\XBMC\cache
12:57:06 T:2400 M:621821952 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
12:57:06 T:2400 M:621821952 NOTICE: Log File is located: C:\Program Files\XBMC\xbmc.log
12:57:06 T:2400 M:621821952 NOTICE: -----------------------------------------------------------------------
12:57:06 T:2400 M:621801472 NOTICE: Setup SDL
12:57:06 T:2400 M:620982272 NOTICE: load settings...
12:57:06 T:2400 M:620933120 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:57:06 T:2400 M:620929024 NOTICE: loading special://masterprofile/guisettings.xml
12:57:06 T:2400 M:620101632 NOTICE: Getting hardware information now...
12:57:06 T:2400 M:620089344 NOTICE: Checking resolution 10
12:57:06 T:2400 M:620089344 NOTICE: Setting autoresolution mode 12
12:57:06 T:2400 M:620048384 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
12:57:06 T:2400 M:620032000 NOTICE: Default DVD Player: dvdplayer
12:57:06 T:2400 M:620032000 NOTICE: Default Video Player: dvdplayer
12:57:06 T:2400 M:620032000 NOTICE: Default Audio Player: paplayer
12:57:06 T:2400 M:620412928 NOTICE: special://masterprofile/sources.xml
12:57:06 T:2400 M:607453184 NOTICE: GL_VENDOR = NVIDIA Corporation
12:57:06 T:2400 M:607453184 NOTICE: GL_RENDERER = GeForce 7300 SE/7200 GS/PCI/SSE2/3DNOW!
12:57:06 T:2400 M:607453184 NOTICE: GL_VERSION = 2.1.2
12:57:06 T:2400 M:607453184 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_framebuffer_object GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
12:57:35 T:2400 M:601075712 NOTICE: start dvd mediatype detection
12:57:35 T:2400 M:601059328 NOTICE: initializing playlistplayer
12:57:35 T:2400 M:601059328 NOTICE: DONE initializing playlistplayer
12:57:35 T:2400 M:602882048 NOTICE: load default skin:[MediaStream]
12:57:35 T:2400 M:594345984 ERROR: Window Translator: Can't find window settingscategory
12:57:35 T:2400 M:594333696 ERROR: Error evaluating boolean expression !Window.Previous(0) + !Window.Previous(SettingsCategory) + !Window.Previous(1001) + !Window.Previous(130) + !Window.Previous(34)
12:57:36 T:2400 M:590467072 NOTICE: Updating video library on startup
12:57:37 T:2400 M:590209024 NOTICE: Updating music library on startup
12:57:38 T:2400 M:590725120 NOTICE: initialize done
12:57:38 T:2400 M:590716928 NOTICE: Running the application...
12:57:38 T:2400 M:590344192 NOTICE: ES: Starting event server
12:57:38 T:500 M:590286848 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
12:57:38 T:500 M:589905920 NOTICE: UDP: Listening on port 9777
12:57:42 T:3156 M:570281984 ERROR: PICTURE::DoCreateThumbnail: Unable to create thumbfile special://masterprofile/Thumbnails/Music/e/e470cbd4.tbn from image k:\audio\Bonobo\Sweetness\folder.jpg
12:57:45 T:3156 M:573624320 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:07
12:59:02 T:652 M:596856832 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\Heroes\
12:59:02 T:652 M:596852736 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\Kenichi\
12:59:02 T:652 M:596897792 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\cat\
12:59:02 T:652 M:596893696 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting k:\tv\random\
12:59:59 T:652 M:597151744 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:00:50 T:652 M:597090304 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:01:41 T:652 M:597536768 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:02:32 T:652 M:597954560 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:03:23 T:652 M:596320256 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:03:40 T:2400 M:577695744 ERROR: CGUIWrappingListContainer::SelectItemFromPoint: Speed 1.000000
13:03:40 T:2400 M:577683456 ERROR: CGUIWrappingListContainer::SelectItemFromPoint: Speed 1.000000
13:03:40 T:2400 M:577679360 ERROR: CGUIWrappingListContainer::SelectItemFromPoint: Speed 1.000000
13:03:40 T:2400 M:577679360 ERROR: CGUIWrappingListContainer::SelectItemFromPoint: Speed 0.852232
13:03:40 T:2400 M:577679360 ERROR: CGUIWrappingListContainer::SelectItemFromPoint: Speed 0.698214
13:04:14 T:652 M:577331200 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:05:05 T:652 M:593498112 ERROR: CFileCurl::CReadState::Open, didn't
13:21:13 T:652 M:598020096 NOTICE: My Videos: Scanning for video info using worker thread, operation took 23:36
LOG:
