Full Version: Video Libary does not display TV/Movoes from local external drive
The strange thing is that it successfully scans my files. When I look at episode details it shows the correct number of episodes.
Also, if I use a skin that has the last 3 added on the home page, I an launch them from the home page.
But when I go to TV Library --> TV Series I get an empty listing.
I use transparency but tried it in PM3.HD and had the same issue.
debug log --> http://pastebin.com/m564e9a49
fstab (just in case) --> http://pastebin.com/m76ed8f86
SVN: 24743 (but has been happening for a while.)
Distro: Debian sid
Arch: x86_64
Kernel: Linux 2.6.31-1-amd64
Install Method: Compile
That's not a debug log. Make sure to enable debug logging in System.
I'm not sure I quite understand the problem - you say that episode counts are OK, yet you don't see anything at the tvshow level? (If so, how do you have the episode count information?)
Cheers,
Jonathan
When I click video info I can see the TV series details but when I click on the name of the tv series, I have an empty list.
Is the debug better? I enabled debugging in settings (I missed that step - sorry)
http://pastebin.com/m233fc2a9
Looks like you don't have a matching source for that path. You have the master lock enabled, correct?
Looks like that source won't exist on sources.xml, right? Is it one that pops up automatically when the external disk is plugged in?
Cheers,
Jonathan
It's in my fstab so it is already mounted before xbmc starts.
The strange think is that it works when I launch it from the home screen using skins that show the last three episodes added.
***The above still stands but you were right to look at sources.xml. It missing and adding it solved my problem.
