Full Version: [LIVE] Crash after adding source to library
The ability to add plugins to the library should be either fixed or the source should be read as a plugin and the user should not be given the opportunity to add the plug-in to the library.
Here's the log for adding a plugin to the library
http://pastebin.com/m4915f652
Here's the resulting log from the resulting GUI freeze
http://pastebin.com/m5b183012
The only soloution is to delete the library after, this is a bandaid. The bug will require a patch.
