2009-11-20, 10:19
Hi there,
First post here, so hi all and thanks to everyone involved for this great piece of software that is XBMC.
Ok, here's the thing. I setup XBMC (the latest stable version 9.04.1-repack2) under Windows. My Video library has been scraped into my video library and everything works fine.
Video sources are coming from a FreeNAS Samba share, so they are not stored locally on the HDD but on the network (if that matters for what is to come :-) )
However, I've setup a Mapped network drive and it is this network drive which I added as a video source in XBMC. I didn't directly add the Samba share (maybe I should?)
So, after everything has been setup properly, I enabled the UPnP server, turned on my Xbox 360. It happily connected to the XBMC Media Server. I could also navigate the whole video libary. However, once I choose a video file and try to play it back, nothing happens. It just doesn't start. No message from the 360 like missing codec or whatever. Just nothing happens.
Now here's a thought that just crossed my mind while writing (though I can't test right now as I'm not home):
I didn't add a video source under UPnP Video Shareing sources (or whatever it is called). Nevertheless, my libary was display on the 360. It just didn't playback. Could this be related? Do I need to explicitely add the Sources in the UPnP settings screen for the streaming to work?
I read somewhere that there could be problems when the folder depth is to deep. I have TV Shows\Show Name\Season XY\Episode.avi. That shouldn't be a problem.
Oh yeah, the video files are fine as I can stream them directly from my FreeNAS box using Fuppes (another UPnP Media Server Software).
Hope someone can provide help.
Edit: Forgot to say that I'm running Windows 7
