I have worked out why I cannot scrape anything, the move to alpha two, turned all scraping off. Nice one.
So I am trying to turn them back on and even though the option to use folder names as look ups is there I am not allowed to select it.
Actually the problem runs deeper. I set the content and as soon as I hit OK it loses that information.
Here is the log.
http://pastebin.com/m346b1d25
I am off to try a different build
You used a new version.
It updated your database to a newer db version.
You then went back to an old version but you have a new db.
As the log says, it can't load the newer db.
Cheers,
Jonathan
I am using the latest build now I think 24368, same problem. I set content click OK, but no option for scanning go back into set content and its back to none.
http://pastebin.com/m7bae93a2
Is my library spooged, do I need to start again?
The latest build thus far is Camelot Alpha 2, which was r24543.
Camelot Beta 1 will be out tomorrow.
Cheers,
Jonathan
Right sorry about that, I thought nightly builds were the latest builds as it were.
I will start the library again, its totally spooged.
