2009-11-21, 23:05
Hello,
Running XBMC on a Del DImension 8200 w/ NVidia Graphics card (yea, it's old, but it works well ) anyway, I am having some troubles with installing some, but not all plugins.
Here is what happens on the ones that will not install
I select the plugin (video, audio, etc.) and then it comes up with the information sheet which contains nothing useful most times, and then I click install. The screen flashses off and I am back to a login prompt.
Here are the last lines from xbmc.log when I just tried to do it again so I had a log of what happened:
I am assuming that it has somethieng to do with the ERROR: Clearblock part, but I do not know how to fix that. It says the same thing when I try to update the RepoInstaller to 1.8.2, so I did that manually instead but it still says that 1.8.2 is New....
Any help appreciated
13:02:50 T:2683825040 M:142082048 DEBUG: CGUIMediaWindow::GetDirectory (?)
13:02:50 T:2683825040 M:142082048 DEBUG: ParentPath = []
13:02:50 T:2683825040 M:142082048 ERROR: GetDirectory - Error getting ?
13:02:50 T:2683825040 M:142082048 ERROR: CGUIMediaWindow::GetDirectory(?) failed
13:02:50 T:3056297872 M:142082048 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
13:02:50 T:3056297872 M:142082048 DEBUG: Progress dialog
13:02:54 T:3056297872 M:142102528 DEBUG: Load button-focus2.png: 0.2ms (bundled)
13:02:57 T:2683825040 M:142102528 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
13:02:57 T:2683825040 M:142102528 DEBUG: System
13:02:57 T:2683825040 M:142102528 DEBUG: GL: Sharing screen surface for thread 2683825040
13:02:57 T:2683825040 M:142102528 DEBUG: [SVN Repo Installer]: ask() action=install
13:02:57 T:2683825040 M:142102528 ERROR: ClearBlock: Trying to clear non existent block /home/media/.xbmc/plugins/programs/SVN Repo Installer
13:02:57 T:2683825040 M:142102528 DEBUG: [SVN Repo Installer]: < show_info()
13:02:57 T:2683825040 M:142102528 INFO: Scriptresult: Succes
