Full Version: Crash when trying to play mp4 file
When trying to play an mp4 file using xbmc 9.11~alpha1-karmic1 XBMC crashes instantly.
If I manually set the rendering to Software, the file plays. With it set to automatic all other media in my library plays fine.
XBMC Debug log is as follows.
Quote:22:00:53 T:3078530960 M:772698112 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
22:00:53 T:3078530960 M:772698112 DEBUG: OnKey: 61453 pressed, action is 7
22:00:53 T:3078530960 M:772698112 DEBUG: new file set audiostream:0
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers(/home/xbmc/Media/Films/AVI/Test.mp4)
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
22:00:53 T:3078530960 M:772698112 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
22:00:53 T:3078530960 M:771715072 NOTICE: DVDPlayer: Opening: /home/xbmc/Media/Films/AVI/Test.mp4
22:00:53 T:2952764272 M:771715072 DEBUG: thread start, auto delete: 1
22:00:53 T:3078530960 M:771715072 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:00:53 T:2944371568 M:771715072 DEBUG: thread start, auto delete: 0
22:00:53 T:2944371568 M:771715072 NOTICE: Creating InputStream
22:00:53 T:2944371568 M:771571712 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: START
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: Checking for common subirs...
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: Done (time: 2 ms)
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: Searching for subtitles...
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: Done (time: 4 ms)
22:00:53 T:2944371568 M:771571712 DEBUG: CacheSubtitles: END (total time: 7 ms)
22:00:53 T:2944371568 M:771571712 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done
22:00:53 T:2944371568 M:771571712 NOTICE: Creating Demuxer
22:00:53 T:2944371568 M:771571712 DEBUG: Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
22:00:53 T:2944371568 M:760516608 DEBUG: Open - av_find_stream_info starting
22:00:53 T:2944371568 M:760782848 DEBUG: Open - av_find_stream_info finished
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/xbmc/Media/Films/AVI/Test.mp4':
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: Duration: 01:38:09.56, start: 0.000000, bitrate: 1643 kb/s
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: Stream #0.0(und): Video: h264, yuv420p, 704x368 [PAR 1:1 DAR 44:23], 25 tbr, 25 tbn, 50 tbc
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: Stream #0.1(und): Audio: aac, 48000 Hz, 2 channels, s16
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: Metadata
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: major_brand : isom
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: minor_version : 1
22:00:53 T:2944371568 M:760782848 INFO: ffmpeg[AF7F8B70]: compatible_brands: isom
22:00:53 T:2944371568 M:760782848 NOTICE: Opening video stream: 0 source: 256
22:00:53 T:2944371568 M:760782848 NOTICE: Creating video codec with codec id: 28
22:00:53 T:2944371568 M:760782848 DEBUG: FactoryCodec - Video: - Opening
22:00:53 T:2944371568 M:760995840 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(704x368)
Not sure it it's worth my logging a bug?
This is fixed in alpha2.
In the future, please use a pasting service (pastebin.com, pastebin.ca, etc), and include your ENTIRE log, not a clipped version.
TheUni
theuni Wrote:This is fixed in alpha2.
TheUni
Do you really want the 500+ lines of SDLKeyboard + OnKey for me navigating around prior to the event?
Alot of the tasty info (hardware details, driver versions, and XBMC version for example) are at the top of the log, that's why we ask for the whole thing.
