Full Version: Play button visible
When a dvd isn't inside the dvd drive, the play button is visible on this skin ..
I changed the skin to PM3 HD and the play button disappears. It appears when I insert the dvd.
Using windows beta 1.
I'm pretty sure it's meant to be there all the time. If you click it without a disk all you get is a popup window instructing you to insert a disk, so it's really not hurting anybody.
Indeed its meant to be there mainly so all 3 buttons fill up the same space as the XBMC logo at the top of the screen and balance out the look of the screen
