Full Version: xbmc-live.conf not loading setting from ./xbmc
I just updated to 9.11 beta1 on my Jaunty minimal install and by mistake I overwrote the xbmc-live launch script that is in /etc/init.d for autostart.
The problem now is that XBMC launches fine but doesn't load my personal settings and library that are in ./xbmc local folder.
If I start X and XBMC manually everything goes fines.
The xbmc-live script is the default one, I haven't modified it (located in /etc/init.d)
The following parameters have been added to the boot command in menu.lst: xbmc=noredir,nodiskmount,autostart
What should I modify in the script to have it:
-autostart XBMC without login
-load my personal settings and library stored in /home/xbmc/.xbmc
-not create a custom xorg.conf since I want to use the one stored in /etc/X11/
Thanks for your help!
Here's an update to my problem that is still not solved...
I found this post http://forum.xbmc.org/showthread.php?tid=61002&page=2 and tried the following xbmc-live script:
# xbmc-minimal
# init XBMC environment and starts XBMC in fullscreen (if asked to do so)
description     "XBMC-minimal"
author          "Luigi Capriotti - Modified by alanwww1"
start on (filesystem and started hal)
stop on runlevel [06]
pre-start script
    if [ -f /home/xbmc/.xsession ] ; then
        rm /home/xbmc/.xsession
    fi
    if [ -f /tmp/noRestartXBMC ] ; then
        rm /tmp/noRestartXBMC
    fi
end script
script
    exec /usr/bin/runXBMC
end script
post-start script
        /usr/bin/setAlsaVolumes
        /usr/bin/diskmounter
        echo USB0 > /proc/acpi/wakeup
        echo -1 >/sys/module/usbcore/parameters/autosuspend
end script
pre-stop script
    touch /tmp/noRestartXBMC
end script
Unfortunately it didn't work and I get an error on the line containing:
May it be related to the fact that this script has been made for Karmic and I'm running Jaunty?
If anyone has another solution please share!
