Could you add fanart support for plugin root directory like other skins? On M_Redux, PM3.HD and also Confluence plugin fanart working only in video list not on the root directory of plugins...
Just goes to show you how much I use plugins
I didn't even know any of them set the fanart variable.
I shall look into it for you
I don't want to disturb you but do I need trac ticket for this?
hey Jezz please fix this.
Where is @
Jezz_X? 2 years not solved ticket here
queeup:
Tried it a few minutes before...did not have a problem at all...
Requires only a fanart.jpg in addon-root directory...
Did I miss the point?
mad-max
Yep you missed it
I am talking about add-on's root directory. I mean when you start your add-on the first directory.
From add-on when you are using xbmc.setPluginFanart it must be applied all directories on add-on.
queeup Wrote:Yep you missed it I am talking about add-on's root directory. I mean when you start your add-on the first directory.
Ah, ok...got it now...
Will look into it...maybe I can supply a patch tomorrow...
mm
Hey Jezz come on hit last time and fix this before Eden release
