2009-11-23, 06:57
First off, I am a relative Linux noob. I have set up a machine with Debian lenny and installed XBMC.
After fighting with nvidia drivers, upgrading all pakages, and fighting with nvidia drivers again, I can't get XBMC to start.
It never did work, so the package upgrades didn't break it.
When I try to start from a terminal, I get a segmentation fault / core dump.
Here is the crash log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sun Nov 22 18:03:32 EST 2009
XBMC Options:
Arch: i686
Kernel: Linux 2.6.31-1-686 #1 SMP Sun Nov 15 20:39:33 UTC 2009
Release:
LSB Version: core-2.0-ia32:core-2.0-noarch:core-3.0-ia32:core-3.0-noarch:core-3.1-ia32:core-3.1-noarch:core-3.2-ia32:core-3.2-noarch:cxx-3.0-ia32:cxx-3.0-noarch:cxx-3.1-ia32:cxx-3.1-noarch:cxx-3.2-ia32:cxx-3.2-noarch:desktop-3.1-ia32:desktop-3.1-noarch:desktop-3.2-ia32:desktop-3.2-noarch:graphics-2.0-ia32:graphics-2.0-noarch:graphics-3.0-ia32:graphics-3.0-noarch:graphics-3.1-ia32:graphics-3.1-noarch:graphics-3.2-ia32:graphics-3.2-noarch:qt4-3.1-ia32:qt4-3.1-noarch
Distributor ID: Debian
Description: Debian GNU/Linux 5.0.3 (lenny)
Release: 5.0.3
Codename: lenny
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
14:17:17 T:3027941184 M:859754496 NOTICE: -----------------------------------------------------------------------
14:17:17 T:3027941184 M:859754496 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Oct 2 2009 (SVN:22976)
14:17:17 T:3027941184 M:859754496 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
14:17:17 T:3027941184 M:859754496 NOTICE: special://masterprofile/ is mapped to: /home/jbrewer/.xbmc/userdata
14:17:17 T:3027941184 M:859754496 NOTICE: special://home/ is mapped to: /home/jbrewer/.xbmc
14:17:17 T:3027941184 M:859754496 NOTICE: special://temp/ is mapped to: /home/jbrewer/.xbmc/temp
14:17:17 T:3027941184 M:859754496 NOTICE: The executable running is: /usr/bin/xbmc.bin
14:17:17 T:3027941184 M:859754496 NOTICE: Log File is located: /home/jbrewer/.xbmc/temp/xbmc.log
14:17:17 T:3027941184 M:859348992 NOTICE: Setup SDL
14:17:17 T:3027941184 M:858722304 NOTICE: load settings...
14:17:17 T:3027941184 M:858722304 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:17:17 T:3027941184 M:858722304 NOTICE: loading special://masterprofile/guisettings.xml
14:17:17 T:3027941184 M:858722304 NOTICE: Getting hardware information now...
14:17:17 T:3027941184 M:858722304 NOTICE: Checking resolution 12
14:17:17 T:3027941184 M:858722304 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:17:17 T:3027941184 M:858722304 NOTICE: Loaded playercorefactory configuration
14:17:17 T:3027941184 M:858722304 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:17:17 T:3027941184 M:858722304 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:17:17 T:3027941184 M:858722304 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
14:17:17 T:3027941184 M:858722304 NOTICE: Default DVD Player: dvdplayer
14:17:17 T:3027941184 M:858722304 NOTICE: Default Video Player: dvdplayer
14:17:17 T:3027941184 M:858722304 NOTICE: Default Audio Player: paplayer
14:17:17 T:3027941184 M:858722304 NOTICE: special://masterprofile/sources.xml
14:17:17 T:3027941184 M:855683072 NOTICE: Using fbConfig[0]
14:17:17 T:3027941184 M:854274048 NOTICE: GL_VENDOR = NVIDIA Corporation
14:17:17 T:3027941184 M:854347776 NOTICE: GL_RENDERER = GeForce FX 5200/PCI/SSE2
14:17:17 T:3027941184 M:854347776 NOTICE: GL_VERSION = 2.1.2 NVIDIA 173.14.09
14:17:17 T:3027941184 M:854347776 NOTICE: GL_EXTENSIONS = GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
14:17:17 T:3027941184 M:854347776 ERROR: Error: Requested setting (videoscreen.displayblanking) was not found. It must be case-sensitive
14:17:17 T:3027941184 M:854347776 ERROR: GLX: Same window as before, refreshing context
14:17:17 T:3027941184 M:849702912 NOTICE: start dvd mediatype detection
14:17:17 T:3027941184 M:849661952 NOTICE: initializing playlistplayer
14:17:17 T:3027941184 M:849661952 NOTICE: DONE initializing playlistplayer
14:17:17 T:3027941184 M:849661952 NOTICE: load default skin:[PM3.HD]
14:17:18 T:3027941184 M:846540800 NOTICE: HAL: Generating global device list
14:17:18 T:3027941184 M:846540800 NOTICE: LFS: Added - disk | Volume (ntfs)
14:17:18 T:3027941184 M:846540800 NOTICE: LFS: Added - disk | Volume (LVM2_member)
14:17:18 T:3027941184 M:846540800 NOTICE: LFS: Added - disk | Volume (ext2)
14:17:18 T:3027941184 M:845766656 NOTICE: initialize done
14:17:18 T:3027941184 M:845766656 NOTICE: Running the application...
14:17:18 T:3027941184 M:845508608 ERROR: Python script "special://home/scripts/autoexec.py" does not exist
14:17:18 T:2986171280 M:844476416 NOTICE: -->Python Interpreter Initialized<--
14:17:18 T:3027941184 M:844361728 NOTICE: ES: Starting event server
14:17:18 T:2977778576 M:844361728 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
14:17:18 T:3027941184 M:844361728 NOTICE: DS: Starting dbus server
14:17:18 T:2977778576 M:844361728 NOTICE: UDP: Listening on port 9777
14:17:18 T:2960993168 M:844361728 NOTICE: DS: Starting DBUS server in Run Application aka thread
14:17:18 T:3027941184 M:842661888 NOTICE: starting zeroconf publishing
14:17:18 T:2994563984 M:839069696 WARNING: Unable to determine Linux distribution
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Thanks in advance for any help, I'm clueless!
XBMC Options:
Arch: i686
Release:
Release: 5.0.3
Codename: lenny
