2009-11-24, 05:37
I've just started using Transparency and I've noticed a slight usability issue that I thought I should point out. I've been using Rapier and there is a mod for it called TrailerView (http://forum.xbmc.org/showthread.php?tid=59131). The way it works is in one of the views, if a trailer is present, you can press down on the remote and the trailer will start playing onscreen in a small window.
This is very similar to how it's handled in Transparency, which is a really excellent feature. One difference, though, is when the trailer is finished or if you want it to stop playing, you just hit down on the remote again. I use XBMC on AppleTV. Once the trailer starts with Transparency, there's no button press that will make it stop. I finally figured out that if I click over to the option bar, I can navigate to the mini playback control and stop it that way.
I was thinking that it would be really great if the same trailer button that starts playback would also stop it if clicked while a trailer was playing. I'm not sure if this is possible, but it's similar in concept to clicking down to start and then clicking down to stop in Rapier's TrailerView mod.
Anyway, love the skin and appreciate all of the work you've put into it. Thanks!
