2009-11-24, 16:51
Pages: 1 2
2009-11-24, 17:37
I would like to know this as well. Had a really difficult time trying to get Alpha2 installed, si hoping Beta 1 will be up soon.
2009-11-24, 18:12
If alpha2 is installed on your system + works, just compile your own "beta1" via svn. There is a nice guide for that in the wiki.
2009-11-24, 18:51
or just drop out to tty2 (ctrl+f2) and type
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xbmc
sudo apt-get update
2009-11-24, 19:00
Silv8rfox Wrote:or just drop out to tty2 (ctrl+f2) and type
sudo apt-get update
Nice, I'll try that... Thanks.
2009-11-24, 19:06
a new live image (iso) probably won't be build until camelot is actually out, and not in beta/alpha/engineering/whatever status. Considering its like 96% done, just wait
oh oh oh... and don't forget
It's done when it's done.
2009-11-24, 19:11
Evanrich Wrote:a new live image (iso) probably won't be build until camelot is actually out, and not in beta/alpha/engineering/whatever status. Considering its like 96% done, just wait
Well they've been building Live ISO's for the each Alpha So far, so figured maybe they would do the same...
2009-11-24, 20:39
sudo apt-get update
I've just done this to update Live Alpha 2 to Beta 1, but my box only comes up to the login prompt now. I can login and startx to get xbmc running, but it's back to the login prompt after a shutdown or reboot. Is there somthing I need to edit or create to get it logging in and starting on it's own?
Ta
2009-11-24, 20:52
Same issue here. Boots to a prompt every single time. I haven't had a chance to dig into it further, but I will this evening.
EDIT: Fixed it by adding runXBMC to rc.local
2009-11-24, 21:00
Need to update the live.conf at install.....at least that solved my problem
2009-11-24, 21:16
Silv8rfox Wrote:Need to update the live.conf at install.....at least that solved my problem
This is done how?
2009-11-24, 21:52
Not to change the subject, but XBMC live beta 1 is available now on the download page.
2009-11-24, 22:00
cjlesh Wrote:Not to change the subject, but XBMC live beta 1 is available now on the download page.LOL, you're not changing the subject! That is the subject! Thanks for posting!
2009-11-24, 22:17
cjlesh Wrote:not to change the subject, but xbmc live beta 1 is available now on the download page.
ytmnd
2009-11-24, 23:23
I just tried to install it from CD to USB flash drive and I got the standard Ubuntu installation, with partitioning, GRUB bootloader installation, etc.
Was this intentional? As a Linux noob it wasn't too bad for me to fiddle through (didn't install Grub bootloader though as I was testing on a works laptop and didn't want to mess it up.
Pages: 1 2
