Full Version: harmony.xml
Hi, apologies i asked this before couple of weeks ago but got no response so asking again. i have custom function key config on my harmony remote whihc is different than that which comes with default harmony.xml. everytime i update xbmc i have to backup and replace the file. In plex you can place harmony/keymap.xml file in a certain directory in your user/library/app support/plex folder with only the changes you've made and it overrides those keys in the defaults. is there something like that in xbmc as well or do i have to keep backing up and restoring the file with each upgrade? in my app support/xbmc directory for some reason i have a keymaps directory in 3 different places and ive tried placing the changes in all of them with no luck. can someone suggest where i might have to place the harmony.xml file with only custom cahnges for xbmc to recognize it?
user/Library/Application Support/userdata/keymaps/<file goes here>
Cheers,
Jonathan
Do you mean:
user/Library/Application Support/XBMC/userdata/keymaps/<file goes here> ?
ijhammo Wrote:Do you mean:
right
