Full Version: thetvdb.com scrapper issue with 9.11 beta 1 (and alpha2)
TV scrapping does not seem to be working for me in 9.11 beta 1 or alpha 2.
Is there is problem with thetvdb.com, the scrapper or perhaps my setup?
I get this:
DEBUG: found episode based match smb://mythtv-b1/myth/media/tv_shows/3/defying gravity/season 1/defying gravity - s01e13.avi (s1e13) [[Ss]([0-9]+)[\.-]?[Ee]([0-9]+)([^\\/]*)$]
DEBUG: FileCurl::Open(0xa6597b0) http://www.thetvdb.com/api/1D62F2F90030C444/series/104581/all/.zip
INFO: easy_aquire - Created session to http://www.thetvdb.com
DEBUG: FillBuffer: curl failed with code 22
ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
DEBUG: FileCurl::Close(0xa6597b0) http://www.thetvdb.com/api/1D62F2F90030C444/series/104581/all/.zip
ERROR: InternalGetEpisodeList: Unable to retrieve web site
Putting http://www.thetvdb.com/api/1D62F2F90030C...104581/all in my web browser I get a page XML code on the series, so the site is definitely up.
any help would be appreciated.
duplicate of http://forum.xbmc.org/showthread.php?tid=62475
There the author found xbmc is not adding en.zip to the url to properly identify the language.
This is an old odd issue. Reset the content set on your tvshow source or simply start with fresh database.
my be an old issue but only became a problem in the last week or so for me.
Any way fixed by deleting the database and rescanning. Also had to delete the nfo files for the offending files. Gave the same error until the nfo files were deleted.
Thanks for the help.
What was in the nfo files?
