Full Version: Bugs with last SVN
I've installed the last svn yesterday, i have detected bugs:
- there is an inversion for some parameters like 'hide parent directories', 'hide file extensions' , when I enable these parameters the parent directories and file extensions are showned.
- if I am in videos menu in file mode (without choosing the sub menu file mode), I see my files. After that if I go to TV shows or Movies menu and go back to Videos menu, the skin is in library mode. In fact the best situation is to have Tv shows and Movies menus in library mode, and in the videos menu I would like to have the last choose I did in this menu so file mode.
regards
Just FYI two points:
Saying the latest SVN is meaningless since latest is old a few hours later.
XBMC is in a feature freeze this now on the run up to the stable release and is not accepting bug reports on the SVN.
Not trying to be a troll with you just giving you a heads up your post will likely not be received as well as you think it will.
Also see the sticky in this thread on how to post bug reports for maximum chance of getting support.
Cheers Smile
