I had the Xbox DVD Remote/Dongle working with the current stable release (9.04) & Alpha 1, but since Alpha 2 & Beta 1 I can't get it working.
Here's what I've been doing to get it work in previous releases.
Use putty.exe to set root password
Ftp to system (loggin in as root), and replace hardware.conf, lircd.conf, lircmd.conf in /etc/lirc folder, and then replacing the blacklist.conf file in the modprob.d folder.
I was able to do this just fine and dandy through multiple installations of 9.04 & alpha 1, but since alpha 2 & beta 1, all I get is failure.
I have an ASRock 330, a Super Joy Box 10 (Xbox->PC USB adapter), to which I have the Xbox DVD dongle plugged in..
Can someone tell me what I'm doing wrong, or how to do it right? I'm pulling my hair out here
post some info..
from putty type lsusb and see if you have the dongle listed there, if so do type irw and press some buttons on the remote, then you should see som remote codes.
(you might need to sudo lsusb and sudo irw)
typed in "lsusb", looks okay?
Quote:Bus 002 Device 004: ID 045e:0284 Microsoft Corp. Xbox DVD Playback Kit
Bus 002 Device 003: ID 045e:009d Microsoft Corp.
Bus 002 Device 002: ID 05e3:0604 Genesys Logic, Inc. USB 1.1 Hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0930:6545 Toshiba Corp. Kingston DataTraveler 2.0 Stick (4GB) / PNY Attache 4GB Stick
then i type in "irw" and...
Quote:root@XBMCLive:~# irw
connect: No such file or directory
then "sudo irw"
root@XBMCLive:~#
Thank you for your help, oh merciful xbmc god :-)
The
irw included in Karmic seems to have changed its default input file.
Try this:
You should see remote codes when you press any buttons.
If you don't, try
to list all the loaded kernel modules (drivers). There should be one line containing
MCE or
MCE v2.
Finally, type
to check if the lirc daemon is running.
same problem here.. i've actualy installed beta1 from cd (finally! alpha2 doesn't work), but XBOX IR Dongle doesn't work..
irw doesn't read any code from remote, maybe because lircd is configured for MCE that use different codes
could anyone paste all config file necessary for XBOX IR DONGLE/REMOTE?
stich86 Wrote:same problem here.. i've actualy installed beta1 from cd (finally! alpha2 doesn't work), but XBOX IR Dongle doesn't work..
I just follow this guide
http://www.opensourceeffects.net/OSE/node/4
However I also find I have to add "blacklist xpad" in /etc/modprobe.d/blacklist.conf and reboot.
This worked for me on Alpha 2 and beta1 via alpha2 upgrade.
Will try this when I get home and let you fellas know. *fingers crossed*
sigh... here are the results..
irw /dev/lircd
root@XBMCLive:/# irw /dev/lircd
but i noticed there was a lirc0 folder, so i tried that one instead..
irw /dev/lirc0
root@XBMCLive:/# irw /dev/lirc0
connect: Connection refused
next up,
lsmod
root@XBMCLive:/# lsmod
Module Size Used by
snd_hda_codec_nvhdmi 4828 1
snd_hda_codec_via 28988 1
dm_crypt 12928 0
snd_hda_intel 26920 2
snd_hda_codec 75708 3 snd_hda_codec_nvhdmi,snd_hda_codec_via,snd_hda_i ntel
snd_hwdep 7200 1 snd_hda_codec
snd_pcm_oss 37920 0
snd_mixer_oss 16028 1 snd_pcm_oss
snd_pcm 75296 4 snd_hda_intel,snd_hda_codec,snd_pcm_oss
snd_seq_dummy 2656 0
lp 8964 0
snd_seq_oss 28576 0
xpad 10340 0
led_class 4096 1 xpad
nvidia 8873924 38
ff_memless 5188 1 xpad
lirc_atiusb 16284 0
snd_seq_midi 6432 0
lirc_dev 10804 1 lirc_atiusb
snd_rawmidi 22208 1 snd_seq_midi
snd_seq_midi_event 6940 2 snd_seq_oss,snd_seq_midi
snd_seq 50224 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_m idi_event
snd_timer 22276 2 snd_pcm,snd_seq
pcspkr 2332 0
i2c_nforce2 6784 0
snd_seq_device 6920 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmi di,snd_seq
psmouse 56500 0
snd 59204 14 snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm_o ss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_devic e
serio_raw 5280 0
joydev 10272 1
soundcore 7264 1 snd
agpgart 34988 1 nvidia
shpchp 32272 0
snd_page_alloc 9156 2 snd_hda_intel,snd_pcm
parport 35340 1 lp
hid_microsoft 3328 0
usbhid 38208 0
usb_storage 52576 1
forcedeth 54152 0
nothing for mce or mce v2, hmmm?
and now i try
ps aux | grep lircd
root@XBMCLive:/# ps aux | grep lircd
root 3693 0.0 0.0 3036 772 pts/0 S+ 18:32 0:00 grep lircd
still not working :-( --- sad panda
Don't give up yet.
I thought the Xbox DVD Remote was a genuine MCE remote, but apparently it isn't. I have no personal experience with it, but you might try this:
Firstly, you need to disable the xpad module:
sudo nano /etc/modprobe.d/blacklist.conf
Add the following line:
The remote is handled be the atiusb lirc module, which appears on your lsmod output, so that should be ok.
You also wrote that you replaced hardware.conf and lircd.conf, so I'm going to assume they are ok, too.
Check if /etc/lirc/hardware.conf contains the line
Reboot to make sure the xpad module is unloaded.
If you still do not get any input with
irw /dev/lirc0, post the output of
grep lirc /var/log/daemon.log
# This file lists those modules which we don't want to be loaded by
# alias expansion, usually so some other driver will be loaded for the
# device instead.
# evbug is a debug tool that should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# causes no end of confusion by creating unexpected network interfaces
blacklist eth1394
# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
# hardware on its own (Ubuntu bug #2011, #6810)
blacklist snd_intel8x0m
# Conflicts with dvb driver (which is better for handling this device)
blacklist snd_aw2
# causes failure to suspend on HP compaq nc6000 (Ubuntu: #10306)
blacklist i2c_i801
# replaced by p54pci
blacklist prism54
# replaced by b43 and ssb.
blacklist bcm43xx
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
# replaced by asus-laptop (Ubuntu: #184721)
blacklist asus_acpi
# low-quality, just noise when being used for sound playback, causes
# hangs at desktop session start (Ubuntu: #246969)
blacklist snd_pcsp
# EDAC driver for amd76x clashes with the agp driver preventing the aperture
# from being initialised (Ubuntu: #297750). Blacklist so that the driver
# continues to build and is installable for the few cases where its
# really needed.
blacklist amd76x_edac
blacklist xpad
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER=""
# If DEVICE is set to /dev/lirc and devfs is in use /dev/lirc/0 will be
# automatically used instead
DEVICE="/dev/lirc0"
MODULES="lirc_atiusb lirc_dev lirc_i2c"
# Default configuration files for your hardware if any
LIRCD_CONF="/etc/lirc/lircd.conf"
LIRCMD_CONF=""
START_LIRCD="true"
begin remote
name XboxDVDDongle
bits 8
begin codes
SELECT 0x0b
UP 0xa6
DOWN 0xa7
RIGHT 0xa8
LEFT 0xa9
INFO 0xc3
9 0xc6
8 0xc7
7 0xc8
6 0xc9
5 0xca
4 0xcb
3 0xcc
2 0xcd
1 0xce
0 0xcf
DISPLAY 0xd5
BACK 0xd8
SKIP- 0xdd
SKIP+ 0xdf
STOP 0xe0
REVERSE 0xe2
FORWARD 0xe3
TITLE 0xe5
PAUSE 0xe6
PLAY 0xea
MENU 0xf7
end codes
end remote
root@XBMCLive:~# grep lirc /var/log/daemon.log
Nov 25 09:14:18 XBMCLive lircd-0.8.6[804]: lircd(default) ready, using /var/run/ lirc/lircd
Nov 25 19:44:34 XBMCLive lircd-0.8.6[804]: accepted new client on /var/run/lirc/ lircd
Nov 25 19:47:12 XBMCLive lircd-0.8.6[804]: reading in mode LIRC_MODE_LIRCCODE fa iled
Nov 25 19:47:12 XBMCLive lircd-0.8.6[804]: caught signal
Nov 25 19:47:21 XBMCLive lircd-0.8.6[1716]: lircd(default) ready, using /var/run /lirc/lircd
Nov 25 19:47:38 XBMCLive lircd-0.8.6[1716]: accepted new client on /var/run/lirc /lircd
Nov 25 19:52:28 XBMCLive lircd-0.8.6[1716]: reading in mode LIRC_MODE_LIRCCODE f ailed
Nov 25 19:52:28 XBMCLive lircd-0.8.6[1716]: caught signal
Nov 25 19:52:31 XBMCLive lircd-0.8.6[1823]: lircd(default) ready, using /var/run /lirc/lircd
Nov 25 19:52:38 XBMCLive lircd-0.8.6[1823]: accepted new client on /var/run/lirc /lircd
Nov 25 19:52:39 XBMCLive lircd-0.8.6[1823]: reading in mode LIRC_MODE_LIRCCODE f ailed
Nov 25 19:52:39 XBMCLive lircd-0.8.6[1823]: caught signal
Nov 25 19:53:04 XBMCLive lircd-0.8.6[1864]: lircd(default) ready, using /var/run /lirc/lircd
Nov 25 19:53:13 XBMCLive lircd-0.8.6[1864]: accepted new client on /var/run/lirc /lircd
I've rebooted, checked the batteries in the remote, tried my original xbox remote (and a harmony that is programmed to work), tried a different dongle, made sure the usb port was plugged in..
If anyone has anymore advice, I'm all ears :-)
It doesn't look like lircd is running, right?
I had almost the exact same issue as you. After upgrading to beta 1, i copied over all my old config files and blacklist file. No remote at all.
Type sudo lircd from a prompt and see what happens. My init.d/lircd ended up needing some tweaking.
nope, doesn't look like it is running...
root@XBMCLive:~# sudo lircd
lircd: can't open or create /var/run/lirc/lircd.pid
lircd: No such file or directory
root@XBMCLive:~# lircd
doesn't even look like I have lirc in the location it shows...
anyone have any ideas what's going on here?
here's what i've done from start to finish..
format 8gb usb drive, burn beta 1 to a cd-rw, pop it in my ASRock, install, use putty.exe to set root password, ftp in and replaced hardware.conf, lircd.conf & blacklist.conf files.. and of course reboot and check.. but it doesn't appear to be working.. should I be "upgrading" or something, is that even possible, does it matter?
I've tried it all.. including a new install of xbmc live beta 2.. not working for anything... i think i'm gonna give up for a while and just resign myself to using the keyboard.. maybe when the next stable release is out i'll give it another whirl.. i've spent too many hours trying to get this working.. i do appreciate all the help everyone has provided attempting to get this working.
