2009-11-26, 14:37
2009-11-26, 15:23
There are loads of labels that need sorting into a language string.xml and it's no the To-Do List.
2009-11-26, 17:47
You tell me that Alaska strings are codded into the XML's instead of strings.xml, isn't it?
If this is the case it will be a great To-Do thing.
Editing: This is a Concept (I adjusted Customsettings.xml and this section in strings.xml).
If you like it I can continue editing in some way you can supervise my job and strings won't get obsolete.
Link: http://www.megaupload.com/?d=J10GA2LD
