Full Version: Linux Script to Convert AAC Audio to AC3
Pages: 1 2
I've been using your script with mythbuntu (9.10) for a bit and everything worked flawlessly (as it did with ubuntu 10.04).
I've recently moved to arch and couldn't get the script to work. I'm getting the following error(s):
Aften: A/52 audio encoder
Version 0.0.8
(c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al.
/home/laffi/media/movies/AAC2AC3Temp.aac file info:
ADTS, 7305.600 sec, 367 kbps, 48000 Hz
| Config:  5.1 Ch     | WARNING: channels are reordered according to
  ---------------------  MS defaults defined in WAVE_FORMAT_EXTENSIBLE
| Ch |    Position    |
| 00 | Center front   |
| 01 | Left front     |
| 02 | Right front    |
| 03 | Left back      |
| 04 | Right back     |
| 05 | LFE            |
input format: RAW Signed 24-bit little-endian 48000 Hz 6-channel
6-channel audio must have LFE channel
error initializing encoder
The AC3 audio track can be appended (resulting MKV file will contain
the existing audio tracks plus the new ac3 audio track) or the AC3 audio
track can replace all existing audio tracks (resulting MKV file will
contain only the AC3 audio track).
Append or replace (press enter for default of replace) (a/r): r
mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 15 2010 05:19:35
Error: The source file '/home/laffi/media/movies/AAC2AC3Temp.ac3' could not be opened successfully, or retrieving its size by seeking to the end did not work.
I noticed that ubuntu and arch currently have the same version of aften (0.0.8), however mkvtoolnix is different (ubuntu 3.0.0, arch 4.1.1).
Any idea what's causing the problem and how this can be rectified ? Thanks.
Pages: 1 2
