ok last post for the night
updated grub list, rebooted, set cpufreq, pulseaudio -k
possibly slightly better, but still running ~14fps 100% cpu most of the time
the aq and vq vary wildly, sometimes aq is running 99% while vq is running ~10%, at other points aq is bouncing ~10% and vq is ~90%.
when the video bitrate is around 10mbs or less, it usually doing 24fps, but it starts hitting 30-35 mbs, its back to ~14 fps. But then there was also time when it was low bitrate (1-2mbs) and still floating ~14fps.
off topic, I found a wierd behavior: when I play a video from the favorites menu, it always resumes even though I have resume set to off in the options. When I play from the library it loads from the beginning.
gonna clear pulseaudio, svn up and recompile over night.
thanks for your help and patience and sorry for the hassle
http://pastebin.com/m418c2e27
top - 01:35:30 up 38 min, 3 users, load average: 2.03, 2.22, 1.83
Tasks: 112 total, 3 running, 109 sleeping, 0 stopped, 0 zombie
Cpu(s): 31.9%us, 65.1%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 3.0%si, 0.0%st
Mem: 252084k total, 248032k used, 4052k free, 220k buffers
Swap: 1103728k total, 169524k used, 934204k free, 63676k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
7359 tekno 20 0 306m 118m 31m S 99.9 48.1 3:53.97 xbmc.bin
145 root 15 -5 0 0 0 D 0.7 0.0 0:02.00 kswapd0
1 root 20 0 2844 532 484 S 0.0 0.2 0:01.70 init
2 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root RT -5 0 0 0 S 0.0 0.0 0:00.00 migration/0
4 root 15 -5 0 0 0 S 0.0 0.0 0:00.02 ksoftirqd/0
5 root RT -5 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
6 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 events/0
7 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 khelper
41 root 15 -5 0 0 0 S 0.0 0.0 0:01.08 kblockd/0
44 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 kacpid
45 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 kacpi_notify
109 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 kseriod
143 root 20 0 0 0 0 S 0.0 0.0 0:00.04 pdflush
144 root 20 0 0 0 0 S 0.0 0.0 0:00.04 pdflush
186 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 aio/0
1454 root 15 -5 0 0 0 S 0.0 0.0 0:00.00 ksuspend_usbd
