2009-11-28, 13:09
Hello all,
I have been having a problem with camelot beta1.
I am using MPC as an external player for my HD videos. When MPC stops; I go back to XBMC with alt+tab and XBMC is very slow, unusable (more than 150mo ram and 55%CPU). So I have to shut it down after each play.
So I enabled debugging and it generated a 177Mo log.
Here is the first part. The "D3DERR_DEVICELOST" continues until I go back to XBMC at which point it becomes very slow. Here is the end of the log.
Another thing, less frequently, XBMC does not start, it is in the task manager with around 5mo of ram and 0%cpu. I have to reboot my PC to have it working again.
I am on core2duo, 3go Ram, GF 9200mo, win7 and I am using Confluence (great work on that skin by the way).
PS: the video test patterns are not working anymore (blank screen).
Thank for your help.
