2011-07-22, 18:52
2011-07-23, 12:56
im also on xbmc 10.1
the message is:
error script failed: script.watched.flag
which doesnt say to much
the message is:
2011-07-23, 13:57
Ah ok, ya that wasn't very helpful.
But I guess it has trouble getting the watched flag from the db...
Maybe you could turn on debugging and see if it give something more helpful in the log.
2011-08-02, 02:41
Any word on getting this script working on recent builds? Namely the nighties?
2011-08-02, 11:25
I tried to fix it for the nightly, but ran into a problem I can't figure out.
The old version (1.0.1) I can install without problem, but it gives you errors when you run it.
I rewrote it to work with the nightly (20110731), worked like a charm. But when I zip it and try to install from scratch I get the error "Addon does not have the correct structure." and it don't get installed.
Maybe someone know what the problem is.
Here is my new version (1.1.0) http://dl.dropbox.com/u/3317056/script.watched.flag.zip
If you want to try it, install the old one and replace the default.py from my zip.
2011-08-02, 21:51
Fox Wrote:I tried to fix it for the nightly, but ran into a problem I can't figure out.
Hey, it works! Great work Fox! I have over 3300 movies and almost half of them are watched, so needless to say, you saved me a lot of work.
2011-08-02, 21:56
Thats good to hear!
Did the installation work for you or did you have to do it the manual way?
2011-08-02, 22:04
I had to copy over the new default.py to the old installation. I was getting the same error as you. Once the installation issue is fixed, you should find out about adding it to the official repo. It's an essential tool for anyone with large libraries.
2011-08-02, 22:07
Ok, good to know it's not only for me. Thanks
Ya I been thinking about that too, but with the low interest in here before I thought maybe it's not that important, but we'll see.
2011-08-04, 14:02
2011-08-04, 21:25
Nice! Glad to see u got it working properly.
2011-08-05, 00:00
I just installed new version but I have a error:
I use MySQL database,
thanks for any help
23:54:29 T:740 M:2318139392 INFO: -->Python script returned the following error<--
23:54:29 T:740 M:2318139392 ERROR: Error Type: pysqlite2._sqlite.OperationalError
23:54:29 T:740 M:2318139392 ERROR: Error Contents: no such table: files
23:54:29 T:740 M:2318123008 ERROR: Traceback (most recent call last):
File "C:\Users\castortray\AppData\Roaming\XBMC\addons\script.watched.flag\default.py", line 107, in ?
exportWatched(mydisplay)
File "C:\Users\castortray\AppData\Roaming\XBMC\addons\script.watched.flag\default.py", line 77, in exportWatched
writeExportFile(movieSQL,movieFile)
File "C:\Users\castortray\AppData\Roaming\XBMC\addons\script.watched.flag\default.py", line 53, in writeExportFile
dbCur.execute(strSQL)
OperationalError: no such table: files
23:54:29 T:740 M:2318123008 INFO: -->End of Python script error report<--
23:54:29 T:1032 M:2318057472 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
23:54:29 T:740 M:2318057472 INFO: Python script stopped
23:54:29 T:740 M:2318057472 DEBUG: Thread 740 terminating
thanks for any help
2011-09-07, 14:28
Sorry for delay on the answer castortray, I've been on holiday.
But there is still no support for MySQL, I don't have a server running to test it on atm.
But if you know of an addon that read/write to the db that works with mysql I could have a look at it and see if I could implement something similar.
2011-09-16, 22:15
I got the following error:
I replaced
with
and now its working.
I'm using Ubuntu 11.04 and a xbmc nightly build.
22:05:50 T:2949634928 ERROR: Error Type: <type 'exceptions.ImportError'>
22:05:50 T:2949634928 ERROR: Error Contents: No module named ElementTree
22:05:50 T:2949634928 ERROR: Traceback (most recent call last):
File "/home/xbmc/.xbmc/addons/script.watched.flag/default.py", line 23, in <module>
import ElementTree as ET
ImportError: No module named ElementTree
I replaced
from elementtree import ElementTree
from xml.etree.ElementTree import ElementTree
2011-09-26, 08:22
I guess you changed the "import ElementTree as ET" line?
Weird that you get that error because it should be included in the resources folder.
I'll have a look at it for the next release.
