Full Version: How to translate "Use pixel buffer objects"
What is this function doing ?
I found a corresponding changeset:
http://trac.xbmc.org/changeset/25040
Could you please help us describe this function ?
Thx
Alan
Yea It's difficult to translate... Maybe remove from settings to advancedsettings.xml?
It's in development branch, the setting won't be in stable, we wouldn't have such a troublesome setting in stable, probably not even in as.xml. If it works it'll always be on.
So don't you worry about it. Short story it will use pixel buffer objects to speed up rendering, about 5-25% on 1080p is the preliminary results, I leave it to bobo1on1 to correct me on this since I'm far from good at it Smile
Cheers,
Tobias
Thanks for the info.
