2009-11-30, 17:55
I was wondering if the high quality resizers are temporarily gone while Camelot is in alpha/beta, and if so, will they be reintroduced when a stable release is out - OR - if for some reason they are still in the program but need some hidden setting to enable them?
I have an ATI HD3200 (780G IGP) and an Athlon 64 X2 5600+ running on WinXP32SP3 with Catalyst 9.10 and have the full DirectX runtimes installed (DIRECTX End-User Runtime version 9.27.1734 ( 982009 ). The only scaling options that ever show up are Nearest Neighbor and Bilinear, I never see Bicubic in the list of options (which does show up and work on this same machine with the 9.04 builds - '9.04.1-repack2' and also 'Rev24195').
I also see exactly the same on my Dell Vostro 1510 laptop with WinXP32 SP3 and an Intel Core Duo T5670 (1.87 GHz) with an Intel Mobile 965 Express IGP (no bicubic on 9.11 builds, but it's there and functional on the older 9.04 builds).
Finally, I've seen older discussion about the Lanczos resizer being available, but didn't ever see that in either the 9.04 builds or the 9.11 alphas and beta - is that also gone, or am I missing a setting?
Many thanks!
The REAL Joe
Many thanks!
The REAL Joe
