Full Version: Video Playback Problem for XBMC 9.11 B1 on AppleTV
I'm running into problems getting video to play for mythtv. I can scroll thru all the recordings and the recording even displays thumbnails; however I can not get the video to play. After a while it says playback failed and the following is what I get from the log. I've read and reread the wiki to no avail. I've scoured these forums. I've verified that I can telnet into the mythtv server (telnet 192.168.0.103 6543). I'm running version 0.22 of mythtv. Any suggestions?
21:17:03 T:52021760 M: 20471808 DEBUG: thread start, auto delete: 0
21:17:03 T:52021760 M: 20463616 ERROR: GetControl - unable to connect to server on 192.168.0.103:6543
21:17:03 T:52021760 M: 20463616 ERROR: GetDirectory - Error getting myth://mythtv:[email protected]/recordings/
21:17:03 T:52021760 M: 20463616 ERROR: GetDirectory - Error getting myth://mythtv:[email protected]/movies/
21:17:03 T:52021760 M: 20439040 ERROR: GetDirectory - Error getting myth://mythtv:[email protected]/tvshows/
21:17:03 T:52021760 M: 20439040 DEBUG: Thread 52021760 terminating
biscuithead Wrote:I'm running into problem getting video to play for mythtv. I can scroll thru all the recordings and the recording even displays thumbnails but I can not get the video play. After a while it says playback failed and the following is what I get from the log. I've read and reread the wiki to no avail. I've scoured these forums. I've verified that I can telnet into the mythtv server (telnet 192.168.0.103 6543). I'm running version 0.22 of mythtv. Any suggestions?
add your mythtv backend to /etc/hosts
Thanks for the quick reply.
I thought I only had to do this if I named my backend something. I'm accessing it via the IP directly.... myth://mythtv:[email protected] Should I also run a DNS? Is there a particular name I should use for /etc/hosts?
biscuithead Wrote:Thanks for the quick reply.
use the name of your backend myth box.
I added my server IP and name to /etc/hosts but I still can't play video. The following is from my log file. I even added the source again using the server name vice the IP. myth://mythtv:mythtv@mythBE - As before, I can see all the recorded shows with the thumbnails but when I hit play it bombs and eventually after several minutes it gives me a prompt saying payback failed. Any suggestion?
01:34:07 T:2684407808 M: 21667840 DEBUG: CGUIMediaWindow::GetDirectory (myth://mythtv:[email protected]/tvshows/Cops/)
01:34:07 T:2684407808 M: 21667840 DEBUG: ParentPath = [myth://mythtv:[email protected]/tvshows/]
01:34:08 T:52140032 M: 21590016 DEBUG: thread start, auto delete: 0
01:34:08 T:52140032 M: 21016576 DEBUG: Thread 52140032 terminating
01:34:13 T:2684407808 M: 21000192 INFO: CheckIdle - closing idle connection to MythTV backend: 192.168.0.103
01:34:13 T:2684407808 M: 20918272 DEBUG: new file set audiostream:0
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerCoreFactory::GetPlayers(myth://mythtv:[email protected]/tvshows/Cops/1005_20091128200000.mpg)
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: hdhomerun/myth/rtmp/mms/udp
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: adding player: DVDPlayer (1) for rule: hdhomerun/myth/rtmp/mms/udp
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
01:34:13 T:2684407808 M: 20897792 DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
01:34:13 T:2684407808 M: 20832256 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
01:34:13 T:2684407808 M: 20828160 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
01:34:13 T:2684407808 M: 20828160 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
01:34:13 T:2684407808 M: 20828160 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
01:34:13 T:2684407808 M: 20828160 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
01:34:13 T:2684407808 M: 19558400 DEBUG: CGUIAudioManager:Big GrineInitialize
01:34:13 T:2684407808 M: 19636224 NOTICE: DVDPlayer: Opening: myth://mythtv:[email protected]/tvshows/Cops/1005_20091128200000.mpg
01:34:13 T:51535360 M: 19623936 DEBUG: thread start, auto delete: 1
01:34:13 T:2684407808 M: 19615744 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
01:34:13 T:51681280 M: 19611648 DEBUG: thread start, auto delete: 0
01:34:13 T:51681280 M: 19611648 NOTICE: Creating InputStream
01:34:13 T:51681280 M: 19570688 ERROR: SetupRecording - unable to connect to file
01:34:13 T:51681280 M: 19570688 ERROR: CDVDPlayer::OpenInputStream - error opening [myth://mythtv:[email protected]/tvshows/Cops/1005_20091128200000.mpg]
01:34:13 T:51681280 M: 19570688 NOTICE: CDVDPlayer::OnExit()
01:34:13 T:51681280 M: 19570688 NOTICE: CDVDPlayer::OnExit() deleting input stream
