Full Version: [REQUEST] Login to megaupload.com to stream divx
I was wondering if anyone could make a plugin that was able to login to megaupload.com and grab the premium link to stream to xbmc. It would just be taken from a simple site like this http://zoso1964.110mb.com/index.html where i can add my movie archive. To motivate someone to build this plugin i will buy them a 3 month premium membership.
could anyone at least point me in the right direction of how to make the plugin login to megaupload.com. I looked at the tv shack mega premium and ninjavideo plugin that login to megavideo.com but i have no idea how to modify them to my needs.
bump
tv shack does that, unfortunatelly, plugin stopped working a week ago.
I wouldn't worry to much as plugin author, Voinage, will fix it soon.
He didn't login for two weeks, but I'm pretty sure he'll solve the problem ASAP.
Cheers...
Actually this has been already done by the Plugin Master Voinage with the help of tvalacarta, and is available and working. you can enter your login info the settings window within xbmc. it's available for both tvshack and ninjavideo <-- love it. you can download here.
http://code.google.com/p/voinage-xbmc-pl...loads/list
dont forget to right click on the plugin from within xbmc interfance and click on plugin settings then enter your megavideo or megaupload account info...
Kushboi
I'm pretty sure it is no longer working, anyone had any updates from the man himself?
lestat1977uk Wrote:Kushboi
I am using it as we speak.. all the flash and divx links work, tvshack also.. and yes indeed Voinage updated them as i requested couple of months ago.
