Full Version: XBMC under WINDOWS 7, runtime error
Hi there,
I installed win 7 today and one of the first thing I did was to install XBMC ofc.
However, when I try to start it I get the following error:
I've tried searching the forums but I only find solutions involving changing the gpu drivers, but they are newly installed and fully functional (in every other app/game so far). I'm currently using GeForce Forceware 190.38 Vista and Win 7 (64-bit) WHQL driver.
I'm using Nightly build r25010 and no skins installed yet. I have a Q9550 2.83GHz processor, 4GB ram, running windows 7 professional 64-bit.
This is my debug log:
Quote:05:14:33 T:2916 M:3037212672 NOTICE: -----------------------------------------------------------------------
05:14:33 T:2916 M:3037212672 NOTICE: Starting XBMC, Platform: Windows build 7600. Built on Nov 25 2009 (SVN:25010, compiler 1500)
05:14:33 T:2916 M:3037212672 NOTICE: Intel® Core™2 Quad CPU Q9550 @ 2.83GHz
05:14:33 T:2916 M:3037208576 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
05:14:33 T:2916 M:3037208576 NOTICE: Running with restricted rights
05:14:33 T:2916 M:3037208576 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
05:14:33 T:2916 M:3037208576 NOTICE: special://masterprofile/ is mapped to: C:\Users\Robert\AppData\Roaming\XBMC\userdata
05:14:33 T:2916 M:3037208576 NOTICE: special://home/ is mapped to: C:\Users\Robert\AppData\Roaming\XBMC
05:14:33 T:2916 M:3037212672 NOTICE: special://temp/ is mapped to: C:\Users\Robert\AppData\Roaming\XBMC\cache
05:14:33 T:2916 M:3037212672 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
05:14:33 T:2916 M:3037212672 NOTICE: Log File is located: C:\Users\Robert\AppData\Roaming\XBMC\xbmc.log
05:14:33 T:2916 M:3037192192 NOTICE: Setup SDL
05:14:33 T:2916 M:3036393472 NOTICE: Found mode: 640x480 @ 59.94 - Full Screen
05:14:33 T:2916 M:3034537984 NOTICE: Found mode: 1440x900 @ 59.94 - Full Screen
05:14:33 T:2916 M:3034673152 NOTICE: load settings...
05:14:33 T:2916 M:3034669056 NOTICE: special://profile/ is mapped to: special://masterprofile/
05:14:33 T:2916 M:3034664960 NOTICE: loading special://masterprofile/guisettings.xml
05:14:33 T:2916 M:3034603520 NOTICE: Getting hardware information now...
05:14:33 T:2916 M:3034603520 NOTICE: Checking resolution 12
05:14:33 T:2916 M:3034591232 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
05:14:33 T:2916 M:3034583040 NOTICE: Loaded playercorefactory configuration
05:14:33 T:2916 M:3034583040 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
05:14:33 T:2916 M:3034583040 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
05:14:33 T:2916 M:3034578944 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
05:14:33 T:2916 M:3034578944 NOTICE: Default DVD Player: dvdplayer
05:14:33 T:2916 M:3034578944 NOTICE: Default Video Player: dvdplayer
05:14:33 T:2916 M:3034578944 NOTICE: Default Audio Player: paplayer
05:14:33 T:2916 M:3034570752 NOTICE: special://masterprofile/sources.xml
I let some repeating stuff out, here's the full log:
http://pastebin.com/m59d9838f
Please come with suggestions on how I can try to make XBMC work for me. If I've missed some information, please do tell and I'll edit the post asap.
Thanks in advance,
reta
Create an advancedsettings.xml file (in your userdata folder - the log shows you where that is) containing:
<advancedsettings>
  <loglevel>2</loglevel>
</advancedsettings>
Then grab the log - it will hopefully contain some more information.
jmarshall Wrote:Create an advancedsettings.xml file (in your userdata folder - the log shows you where that is) containing:
<advancedsettings>
</advancedsettings>
OK, here is the log after the change in advancedsettings:
http://pastebin.com/m2aff2044
<advancedsettings>
</advancedsettings>
Is this a new feature?
i had to download dxwebsetup and run it before I installed xbmc and I believe there is a dll file you also need to install.. do a search for windows 7 and you will find what you need..
dxwebsetup is included in the beta build and you need a working internet connection during installation.
Hi guys! I've the same problem... Someone found a solution? I've installed last Directx 9 because before it ask me a .dll file... But now it don't ask me more dll but it make me the same error... Thank you bye bye
Same here...
Windows 7
Intel E5300
Nvida geforce 9300/nforce 730i
*UPDATE*
I got it to work
Ive found that you can start it from C:\programm (x86)\Xbmc\xbmc.exe
If you push the windows bottom and choose properties at XBMC (portable) and in target field remove -p and apply.
Sorry but i don't understand where -p is.. Can you explain better? I open .exe properties but i see only XBMC.exe in properties without any -p. Thank you bye
On the desktop.
Push the windows logo botton down to the left.
Find xbmc folder and right click on "xbmc portable" and choose propertis.
In the target field should say ""C:\programs (x86)\xbmc.exe" -p"
(If you have installed it on c: )
Remove -p and apply
and the holy grail will unveil
mmm i don't have portable version... what version of XBMC do you use? I Use the nighlty build... It's not the same I think
I use Camelot
I had the same problem when trying to launch XBMC from the start menu or the quick launch icon. But when using xbmc.exe directly from the XBMC folder, it works just fine. I created a shortcut to the desktop and launch it from here
Sounds like you all have an old shortcut with the -p switch on it. Remove it.
I have the same issue but happens when I close xbmc. I install Microsoft visual C++ 2008. added that avancedsttings xml, updated video drivers. I have no idea what to do.
This started after I reinstall Windows 7 on my laptop.
