2009-12-04, 21:26
2009-12-04, 21:28
Settings > Videos > File Lists > Extract thumbnails and video information
2009-12-04, 22:43
Thanks Ronie.
2009-12-05, 00:03
I did this but it does not do what it says it will (It was already set). I only have one set of tv shows that have no thumbs (Scooby doo, TVDB has nothing for them)
When I goto scooby doo. I only get generic folder icons even though get thumbs is highlighted.
2009-12-05, 00:22
garyi Wrote:I did this but it does not do what it says it will (It was already set). I only have one set of tv shows that have no thumbs (Scooby doo, TVDB has nothing for them)
xbmc.log might show why its happening.
2009-12-05, 09:40
http://pastebin.com/m710013ce
Here you go then, I restart XBMC and navigated around scooby doo. The generate thumbs is switched on, but no thumbs
2009-12-05, 10:21
garyi Wrote:http://pastebin.com/m710013ce
there is not even a call for thumb creation.
- try Tv Show Information -> refresh
or
- removing it from the library, browse to it in file view it should generate the thumbs and after that add it to library again.
if you dont mind posting file names, and the folder structure I could try and recreate the issue.
Zeljko
2009-12-05, 11:37
Hi,, well this morning I deleted some movies from my harddrive as I needed the space. As XBMC has no way of deleting a bunch of films I actually removed the entire videos database so had to redo TV shows from scratch, I guess this is as good as refreshing. Still the same thing.
As for folder structure:
Scooby and Scrappy Doo
. Season 1, 2, 3 etc
.. Scooby and Scrappy Doo S01E01, S01E02 etc
The top level has a fanart and folder jpg as well season-all.tbn and tvshow,nfo, both generated from the export library function. Each episode also has and nfo, again generated from XBMC export library function.
Its only this folder, but there again its only this folder the TVDB has no images for.
2009-12-05, 11:54
FYI, fixed in SVN r25307. Thanks ccMatrix.
2009-12-05, 20:19
OK if I download the latest SVn is it newer than the beta or a different branch or whatever, I do get confused with all this lol.
2009-12-06, 02:38
Latest is no version If you want it really bad, search for nightly builds > r25307 or wait for next official pre-release.
