Full Version: Why is there no <aligny>bottom<aligny> ?
Pages: 1 2
jer <bottom>"foo"</bottom> is a possible (Helix?) replacement for <posy>"foo"r</posy> and should have the same effect as <top>"foo"r</top>. Wiki
Thanks Phil
<aspectratio aligny="bottom">keep</aspectratio>
did work in the Imagecontrol.
(Seems this info is missing in the wiki)
never thuth about try it this way. what i did try was: <texture background="true"aligny="bottom">$INFO[Container(9101).ListItem.Icon]</texture> which didnt work.
Now the one which is left is how to align a label to the bottom (<wrapmultiline>true</wrapmultiline>)?
r there any ways?
Regards
I faked it it for Copacetic using a right-aligned, vertical grouplist + auto height textbox.
PHP Code:
<control type="grouplist">
top>50</top>
height>210</height>
align>right</align>
orientation>vertical</orientation>
control type="textbox">
height max="210">auto</height>
font>Light60Spaced</font>
label>$VAR[InfoTitle]</label>
control>
control
Thanks Hitcher
will give it a Try.
But would be nice to not have to do such a workaround, and simply work with <aliny>bottom</alingy>
Would be much more intuitive. (maby a dev. decide to reopen the Ticket.. ?)
(2009-12-05, 01:10)Hitcher Wrote: [ -> ]From the wiki -
Quote:aligny Can be top or center. Aligns the text within its given label <height>. Defaults to top
Any reason why we can't have <aligny>bottom<aligny>?
I'd specifically like to use it for a wrapmultiline control.
Hi i'd like to know if this feature,  aligny bottom,  will be available for textbox will be very helpful if it does. Thanks in advance
Pages: 1 2
