Hello
First I want to thank all of the developers who gave us this amazing HD skin
I have some suggestions and I hope to see them available in the final release .. if you please
1- Is there any other color themes in the final release ?
2- Can you add the running time to the main info bar .. instead of viewing the info to check the running time ?
3- How can I add more menu items to the home window? like trailers , clips ..etc ?
4- Where is Michael jackson icon that appeared on the demo video ? I want to use it for video clips icon in home wind
5- the fanart mode discussed in another thread
Thanks for your efforts
I've been watching this skin for a while and downloaded the beta today. I was curious if a wide icon view will be supported in the future?
Oops nevermind, just read the plans at the Blackbolt site, can wait to see wides view
costa Wrote:Hello
1) Check the skin settings page in the skin. The second tab has an option at the bottom for a Time Based theme, this is colourful.
2) We're adding the seekbar to the top in next update so you can see time.
3) I can't answer this, but equinox can.
4) He's in there, if scan some music videos, he should appear on home page automatically .
Please replace all ttf fonts in fontset by UNICODE equivalent. This makes life easier for people who want translate strings for own language.
b4sh Wrote:Please replace all ttf fonts in fontset by UNICODE equivalent. This makes life easier for people who want translate strings for own language.
We're working on this now. Can't promise it will be ready for Beta 1.1 (due very shortly, possibly within 24 hours), but should be ok for Beta 1.2 (no date yet).
Looks lovely, really is a top skin. A few things to fix.
My setup is the Xbox.
1. In the Navi-X script in Elipsis there's no text or icons on the screen for some reason and can't see what I'm selecting.
2. Can it support the Opensubtitles_OSD rather than the plugin, is there a hack for it yet?
3. The TV section, the banner shows up a very small section of the banner itself and you can't see it in full. Is there a way to show it all up?
4. Pictures don't show up in full screen when selecting them, just a black screen, the xbox doesn't crash as you can return back to the picture root screen. Any reason why? is it a settings issue?
I'm loving this skin, and is very nearly close to replacing Project Mayhem 3 as my default screen, only for these little bugs and issues I believe Xbox users will use this as their default skin! Really impressive!
Sneakee Wrote:Looks lovely, really is a top skin. A few things to fix.
1. We're looking into this now for you.
2. Added to Beta 1.1 (Now available)
3. You need to set your scraper (in the set content window settings) to default to posters. The banner view types for Ellipsis will not be added for a while yet, 1.0 we're aiming for.
4. We'll have to wait to try replicate this error on an xbox, as I'm pretty sure it works fine on other platforms.
This is going to sound silly but where is the Opensubtitle_OSD button on the Video playback GUI screen. I can't find it on the little control tab in the middle of the screen, I have the Beta 1.1. How do you select the OSD when in video playback mode...thanks!
I wouldn't mind seeing an option for a watched overlay cant get use to unwatched overlay
Scrolling through library is very choppy for me in both showcase and showcase hybrid when the fanarts are on. No problem though when I turn them off.
The "oldschool" behaviour back button take you back to library root and not
Home is a bit annoying when you have been used by recent skins (Mediatream / Aeon / Redux / Confluence) to choose from home via a submenu where you want to go.. So I don't know the plans but maybe adapting the dock be able to select library nods would be an idea...
I hope you'll be adding some more views soon.
Apart from the above, this is a really nice skin. Thanks a lot
RazorFR Wrote:Scrolling through library is very choppy for me in both showcase and showcase hybrid when the fanarts are on. No problem though when I turn them off.
That doesn't sound right as this is the least cpu hungry out of all skins I've used including the ones you listed
>>X<<' Wrote:That doesn't sound right as this is the least cpu hungry out of all skins I've used including the ones you listed
Maybe...
But the fanart loading behaviour seems to be different from the other skins. When scrolling fast with let's say confluence. It seems that the skin is not trying to load new fanarts. Then when you stop on an item then the selection fanart is loading smoothly. With ellipsis it seems different, even when scrolling fast the skin seems to try to load every fanart... Might be a clue, for the choppiness feeling
RazorFR Wrote:Maybe...
ok I'm with you now your talking about scrolling fast through library
Hopefully this should be now fixed and now using largeimage in the appropriate part of the includes.xml (it was taken out due to a bug with largeimage at the time and i had forgotten to put back in)
I have been trying to execute trainers without success. It seems that Ellipsis does not recognize them (the same happens with Confluence).
The trainers list is updated perfectly but then nothing appears.
Anyway, it's a fantastic job. Here is spanish translation (save strings.xml as utf-8)
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<!--Language file translated with Team XBMC Translator-->
<!--Translator: rowan marley-->
<!--Date of translation: 12/15/2009-->
<!--$Revision$-->
<strings>
<string id="50000">Saltar Introducción</string>
<string id="50001">Mostrar Animación Cerberus</string>
<string id="50002">Ocultar Fanart </string>
<string id="50003">Ocultar Visualización de Fondo</string>
<string id="50004">Ocultar Fondo de Vídeo</string>
<string id="50005">Ocultar Superposición</string>
<string id="50006">Ocultar Borde de Viñetas</string>
<string id="50007">Ocultar Texto del Menú</string>
<string id="50008">Ocultar Carpeta Actual / Sección Widget</string>
<string id="50009">Ocultar Superposición No Vistos</string>
<string id="50010">- Archivo:</string>
<string id="50011">Carpeta de Fondos Personalizados</string>
<string id="50012">Ocultar Icono VIDEOS</string>
<string id="50013">Ocultar Icono REPRODUCIR DVD</string>
<string id="50014">Ocultar Icono SERIES DE TV</string>
<string id="50015">Ocultar Icono PELÍCULAS</string>
<string id="50016">Ocultar Icono VIDEOS MÚSICALES</string>
<string id="50017">Ocultar Icono IMÁGENES</string>
<string id="50018">Ocultar Icono PROGRAMAS</string>
<string id="50019">Ocultar Icono EXPLORADOR DE ARCHIVOS</string>
<string id="50020">Ocultar Icono EL TIEMPO</string>
<string id="50021">Ocultar Icono SCRIPTS</string>
<string id="50022">Ocultar Icono MÚSICA</string>
<string id="50023">Ocultar REPRODUCIENDO AHORA</string>
<string id="50024">AJUSTES - CONFIGURAR ELLIPSIS</string>
<string id="50025">PROXIMAMENTE...</string>
<string id="50026">ESPERE POR FAVOR...</string>
<string id="50027">XBMC</string>
<string id="50028">Reiniciar XBMC</string>
<string id="50029">FAVORITOS</string>
<string id="50030">Este archivo tiene varias partes, selecciona una para reproducir:</string>
<string id="50031"> De </string>
<string id="50032">ESC</string>
<string id="50033">BORRAR</string>
<string id="50034">MAYUSCULAS</string>
<string id="50035">SHIFT</string>
<string id="50036">DIRECCIÓN IP</string>
<string id="50037">ESPACIO</string>
<string id="50038">TERMINAR</string>
<string id="50039">Pausar</string>
<string id="50040">Avance Rápido</string>
<string id="50041">Saltar Adelante</string>
<string id="50042">Detener Grabación</string>
<string id="50043">Menú del DVD</string>
<string id="50044">Visualización - </string>
<string id="50045">Configurar Visualización</string>
<string id="50046">Ajustar Visualización</string>
<string id="50047">Ir Atrás</string>
<string id="50048">Regresar</string>
<string id="50049">Detener</string>
<string id="50050">Amo Last.FM</string>
<string id="50051">Odio Last.FM</string>
<string id="50052">Marcadores</string>
<string id="50053">: Encendido</string>
<string id="50054">: Apagado</string>
<string id="50055">Cambiar a Modo Biblioteca</string>
<string id="50056">Cambiar a Modo Archivos</string>
<string id="50057">Ocultar Vistos</string>
<string id="50058">Mostrar Vistos</string>
<string id="50059">Apilar</string>
<string id="50060">Superponer</string>
<string id="50061">Ubicación</string>
<string id="50062">Ajustes de energía</string>
<string id="50063">Guía de navegación del menú</string>
<string id="50064">Información Completa del Sistema</string>
<string id="50065">PRESIONA PARA MAS INFORMACIÓN</string>
<string id="50066">Disco en la Unidad</string>
<string id="50067">Series</string>
<string id="50068">Videos Musicales</string>
<string id="50069">Ajustes - Skin</string>
<string id="50070">Información del Sistema</string>
<string id="50071">Último ingreso:</string>
<string id="50072">Ajustes - Perfiles</string>
<string id="50073">Películas por Género</string>
<string id="50074">Películas por Título</string>
<string id="50075">Películas por Año</string>
<string id="50076">Películas por Actor</string>
<string id="50077">Películas por Director</string>
<string id="50078">Películas por Estudio</string>
<string id="50079">Series por Género</string>
<string id="50080">Series por Título</string>
<string id="50081">Series por Año</string>
<string id="50082">Series por Actor</string>
<string id="50083">Videos Musicales</string>
<string id="50084">Videos Musicales por Género</string>
<string id="50085">Videos Musicales por Título</string>
<string id="50086">Videos Musicales por Año</string>
<string id="50087">Videos Musicales por Actor</string>
<string id="50088">Videos Musicales por Director</string>
<string id="50089">Videos Musicales por Estudio</string>
<string id="50090">Últimas Películas</string>
<string id="50091">Últimas Series</string>
<string id="50092">Últimos Videos Musicales</string>
<string id="50093">Música Por Género</string>
<string id="50094">Música Por Artista</string>
<string id="50095">Música Por Álbum</string>
<string id="50096">Música Por Single</string>
<string id="50097">Música Por Canción</string>
<string id="50098">Música Por Top 100</string>
<string id="50099">Últimos Álbumes</string>
<string id="50100">Últimos Álbumes Reproducidos</string>
<string id="50101">Música por Recopilación</string>
<string id="50102">Música por Año</string>
<string id="50103">Bienvenido a [b]Ellipsis Beta One[/b]. Apreciamos tu elección, y esperamos lo disfrutes tanto como nosotros al crearlo.[CR][CR]Últimas Noticias:[CR][CR][b]Ellipsis Beta One Disponible ahora[/b] - 04 Diciembre 2009[CR][CR]Hoy traemos para ti Ellipsis, el esperado skin para XBMC Media Center. Tomó su tiempo, Pero finalmente hemos logrado algo de lo que estamos muy orgullosos... Para mas información visita [b]http://www.teamblackbolt.co.uk[/b]</string>
<string id="50104">) Elementos - Página (</string>
<string id="50105">Actual</string>
<string id="50106">NAVEGADOR</string>
<string id="50107">[b]Bienvenido a XBMC[/b][CR][CR]Hemos puesto unos enlaces a la izquierda para ayudarle a encontrar lo que necesita más rápido.[CR][CR]Tip: No olvides calibrar tu pantalla correctamente, esto podría mejorar la interfaz![CR][CR]A continuación encontrará las últimas noticias del equipo de XBMC.</string>
<string id="50108">XBMC Archivo RSS:</string>
<string id="50109">Información del Sistema</string>
<string id="50110">IP: </string>
<string id="50111">Internet: </string>
<string id="50112">Resolución:[CR]</string>
<string id="50113"> x </string>
<string id="50114">Memoria Libre:[CR]</string>
<string id="50115">Uso del CPU: </string>
<string id="50116">Tiempo de funcionamiento del sistema:[CR]</string>
<string id="50117"> (Compilación : </string>
<string id="50118">Pantalla de Bienvenida Activada</string>
<string id="50119">Pantalla de Bienvenida Desactivada</string>
<string id="50120">INFORMACIÓN DEL SISTEMA</string>
<string id="50121">Nombre:</string>
<string id="50122">PRESIONA PARA SALIR</string>
<string id="50123">Habilitar tema basado en el tiempo</string>
<string id="50124">Aplanar</string>
<string id="50125">Redondear</string>
<string id="50126">Modo Fiesta</string>
<string id="50127">Terminará de reproducir en</string>
<string id="50128">Subir Siguiente</string>
<string id="50129">Elementos</string>
<string id="50130">Página</string>
<string id="50131">Mostrar botón de descarga de subtítulos en OSD</string>
<string id="50132">DVD híbrido</string>
<string id="50133">Juego</string>
<string id="50134">Juego Híbrido</string>
<string id="50135">Mostrar logeo</string>
<string id="50136">Mostrar Poster/Información</string>
<string id="50137">Mostrar Poster</string>
<string id="50138">Vinilo</string>
<string id="50139">Capturas</string>
<string id="50140">Carátula</string>
<string id="50141">Título/Carátula</string>
</strings>
