i've noticed that with weather fanart enabled, the transition into weather is nicer than going from weather back to home. going back home the screen blacks out.
without fanart it's smooth both ways.
and because you did such a nice job on the twc supplemental skin, i fixed the weekend forecast so update if you use it. i really wish you would skin for the plugin. i may play around with it, since your twc skin is basically all you need with changing property names.
The weather fanart looks fine to me I made it fade in and out on purpose because image is never (well 99%) the same since its 2 different controls that load and give us a different image it looked better than flashing to me
As for the supplemental skin if you make it work or the plugin and make it all seperate file (from weather.xml) to <include> I will add it. (and probably remove the current one)
But it took me ages to do it just to find you saying your never going to update it. I kind of lost the motivation to do anymore with it
i told you long ago the script was obsolete, back when the plugin was made.
about the transition, i'm on win7 directx build. going from weather to home always turns screen black before home shows. not for you?
jezz i'm using string id's above 31900, if you don't mind saving those. i see you added 31500 range for pvr.
how about a courtesy response, since you include my recentlyadded.py in xbmc svn now.
Nuka1195 Wrote:jezz i'm using string id's above 31900, if you don't mind saving those. i see you added 31500 range for pvr.
sure I don't plan on adding anymore big groups of labels anyway but doesn't the plugin contain its own
translateable strings.xml ? why would it need a bunch more just for this skin ?
Nuka1195 Wrote:how about a courtesy response, since you include my recentlyadded.py in xbmc svn now.
Sorry missed it only human I don't read half the stuff people post here on the forum I just graze. plus because of the forum timeout for login things often get marked as "Not New" next time I load the page just because it thinks I was here even though I havn't read them. (anyone else get this problem? its real anoying)
P.S. if you have somthing
really important that you want to make sure I see a PM is the better way. because as I said I can miss forum posts.
P.P.S Everyone this doesn't mean start PMing me for all your little requests and issues
I am a mod and have ban power
so remember
really important only
