2009-12-06, 13:50
Hello, I just installed Ubuntu Karmic and XBMC form PPA repositories.
On Jaunty I had 2 files to config the lirc:
I try to copy thoose files on the userdata directory but it doesn't work. Now I have a "keymaps" directory on userdata.
This is my lirc configuration:
Can you help with this? I will apreciate any help.
Thanks for all and best regards.
cat .xbmc/userdata/Lircmap.xml
<lircmap>
<remote device="RM-ED006">
<forward>ford</forward>
<reverse>back</reverse>
<skipminus>atzea</skipminus>
<skipplus>aurrea</skipplus>
<pageplus>mas</pageplus>
<pageminus>menos</pageminus>
<play>play</play>
<info>info</info>
<left>left</left>
<right>right</right>
<up>up</up>
<down>down</down>
<select>enter</select>
<back>menu</back>
<stop>stop</stop>
<power>shut</power>
<pause>pause</pause>
</remote>
</lircmap>
$ cat .xbmc/userdata/Keymap.xml
<keymap>
<global>
<remote>
<play>play</play>
<info>info</info>
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
<select>Select</select>
<back>PreviousMenu</back>
<volumeplus>VolUp</volumeplus>
<volumeminus>VolDown</volumeminus>
<mute>Mute</mute>
<stop>Stop</stop>
<pause>Pause</pause>
<power>shut</power>
<skipnext>aurrea</skipnext>
<skipprevious>atzea</skipprevious>
</remote>
</global>
</keymap>
$ cat /etc/lirc/lircd.conf
begin remote
name RM-ED006
bits 12
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 2408 572
one 1215 573
zero 620 573
gap 251982
min_repeat 3
toggle_bit_mask 0x0
begin codes
1 0x01A
2 0x81A
3 0x41A
4 0xC1A
5 0x21A
6 0xA1A
7 0x61A
8 0xE1A
9 0x11A
0 0x91A
up 0x43A
down 0xC3A
left 0x47A
right 0x87A
enter 0x8BA
play 0x59A
pause 0x99A
stop 0x19A
ford 0x39A
back 0xD9A
atzea 0x15A
aurrea 0x95A
menu 0xB3A
shut 0xA9A
info 0x5BA
mas 0x09A
menos 0x89A
end codes
end remote
