2009-12-06, 19:10
OK - having some serious issues getting smooth playback with 23.97 (24p) MKV files.
My TV (Bravia KDL40W2000) does not support 24p - only 50hz and 60hz.
Situation at the moment as follows:
- XBMC currently running in 1920x1080p@50hz
- 25fps and 30fps files play smoothly.
- 23.97 (24p) files play, but with a "judder" every second.
Sync playback to display is enabled from the XBMC settings. If I set XBMC itself to 1920x1080p@60hz, it still plays 23.97fps files at 50hz. I have to disable Sync playback to display in order to get 23.97 fps files to playback at 60hz. Even then I still get the same stutter - it makes no difference whether the file is playing using 50hz or 60hz
How can I get 23.97fps files to playback without the one-second stutter? On my TVIX box (6500) the files play fine. Sure, panning shots are not quite as smooth as if my TV supported 24p, but there is no one-second stutter on my TVIX box. Basically I want to get XBMC to play these 23.97fps files in the same way.
My current xorg.conf file is as follows (now with the line Option "DynamicTwinView" "False" included in order access 60hz - as well as the flanpanel scaling line).
What do I need to be doing/changing either in XBMC, xorg.conf, or possible even from the Nvida settings within Ubuntu in order to get things working correctly?
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (buildmeister@builder63) Tue Oct 20 21:01:12 PDT 2009
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Tue Oct 20 21:00:15 PDT 2009
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
ModulePath "/usr/local/lib/xorg/modules"
EndSection
Section "ServerFlags"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: builtin, VertRefresh source: builtin
Identifier "Monitor0"
VendorName "Unknown"
ModelName "SONY TV"
HorizSync 14.0 - 70.0
VertRefresh 48.0 - 62.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "ION"
Option "UseEdidDpi" "false"
Option "DPI" "96 x 96"
EndSection
Section "Screen"
# Removed Option "metamodes" "1280x720 +0+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinViewXineramaInfoOrder" "CRT-0"
Option "TwinView" "0"
Option "metamodes" "1920x1080 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
